Another dedicated?? mower set up?!?!
/ Another dedicated?? mower set up?!?! #1
Worksmart
S.E. Michigan
L6060, BX22, 1953 Farmall Super A, 1949 Farmall Cub, 1964 International Cub, 1966 International Cub, 1976 International Cub
Parents have 23 acres and I set them up with a L3830HST and all the fixin's last fall(Rhino 6' rotary cutter, back blade, box blade, LA723 loader HD quick attach bucket/forks etc.). Now we're looking at something to cut the grass/weeds around the house. Probably 2 acres in total. Not a manicured lawn by any means. Probably 60% weeds, etc. and pretty bumpy.
Currently demo-ing a Kubota G1800 diesel lawn tractor w/60" deck. 1200 hrs and it kinda shows it. Then on the other hand ...don't have to worry about beating it up! Dealer is asking $3900. The deck rolls on the ground and we've gotten it stuck a couple times already....not fun for me or my "senior" aged parents /forums/images/graemlins/frown.gif. It seems to high center occasionally. Would a suspended deck alleviate this "problem." I have a BX22 with a suspended deck. Am I spoiled? /forums/images/graemlins/tongue.gif Then again I'm cutting a flat "manicured" lawn.
If I read correctly the newer 2160 has a suspended deck. Is that the way to go. There are lots of ruts and undulations to deal with. Like I mentioned before....does a suspended deck make a big difference?? I'm also thinking a BX1500/1800 may be the way to go. Used would be O.K. I like the 60" deck of the 1800. A 54" on the 1500 is acceptable. 4wd on both ultimately sounds like the only way to truly avoid the problems we're running into. So much for the budget /forums/images/graemlins/tongue.gif. Some gardening may also be in the future so a tiller on the BX would be pretty cool!!
Was hoping to keep the cost down $3-5,000. /forums/images/graemlins/blush.gif Ease of use is also VERY important. I could always put a belly mower on my '49 Cub but that isn't gonna fly with my parents. Hydrostatic is pretty much a given! I've already spent a bunch of their money on the L3830(awesome machine) so I'm really trying to make another excellent decision /forums/images/graemlins/cool.gif /forums/images/graemlins/smile.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/smirk.gif for them. I mostly run the L3830 and they will be running the lawn tractor.
Chuck
/ Another dedicated?? mower set up?!?! #2
I can't say much on your technical questions about suspended decks, but I just got a G2160 and am quite happy with the cut and the speed I can go. I've read ZTRs are the way to go ultimately for a dedicated mower, but I've also read that if you can't use them to their potential, such as travelling at a good clip (pun intended) as opposed to manuevering on the ground you described, plus the learning curve to get the hang of one, plus the extra $$ and the fact that you can't do a thing with them, but mow... Well, like I said, I just got a G2160. I thought they listed for around $8,000, though, so not sure about the budget numbers you mentioned.
I have had mine stuck already. Hard to go from 4WD to 2. It went up a short steep hill just fine, which surprised me, but get the front wheels down a little incline on some soft turf and, well, the 3130 wasn't that far away /forums/images/graemlins/smile.gif
/ Another dedicated?? mower set up?!?! #3
</font><font color="blue" class="small">(
Currently demo-ing a Kubota G1800 diesel lawn tractor w/60" deck. 1200 hrs and it kinda shows it. Then on the other hand ...don't have to worry about beating it up! Dealer is asking $3900.)</font>
I'd say that is way too much for that machine - before I decided to buy something larger altogether I had my 2003 Kubota TG1860 diesel w/ 34 hrs. for sale at what I thought was a fair price - $4600 - very similar to the G1800 and practically new. Keep looking if you decide to go that route, you can do better than that if you're not in a big hurry.
2019 FORD F-150 XL CREW CAB TRUCK (A59823)
2019 FORD F-150 XL...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
UNUSED FUTURE 30" MINI EXCAVATOR PALLET FORKS (A60432)
UNUSED FUTURE 30"...
2021 CATERPILLAR 308CR EXCAVATOR (A60429)
2021 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A60429)
2021 CATERPILLAR...
