Another brush cutter ?
/ Another brush cutter ? #1
Bever22
If I got a 5' brush cutter for my 2310 and overlap the rows would it work ok? I like to cut my fields on a regualr basis with a brush cutter but would like one a little bigger so I can overlap the rows to get rid of the uncut streaks left behind.
/ Another brush cutter ? #2
A 5ft cutter is too big. You will have stablitiy problems when trying to lift the cutter and the inertia required to start and stop the load of the 5' blades is probably more than the tractor is designed for. Suggest you use a 4' cutter.
/ Another brush cutter ? #3
Yes 4ft or even a 42" if cutting heavier stuff.
48" it is, thanks for the help.
I purchased the 4' today, thanks for the info.
Kewanee 12A Cultamulcher (A66408)
Kewanee 12A...
IRANCH IRGC40 ELECTRIC SCOOTER (A64280)
IRANCH IRGC40...
New/Unused Landhonor 24in Semi-Automatic Tire Changer (A65583)
New/Unused...
2020 GMC AT4 CREW CAB TRUCK (A64280)
2020 GMC AT4 CREW...
John Deere 18ft. 3 Point Field Cultivator (A65640)
John Deere 18ft. 3...
Cattle Feeder (A65640)
