Another broken tooth
/ Another broken tooth #1
plants4u
Puyallup WA
Kubota L2800DT
Is it just me or what? I've managed to break two teeth off of my backhoe bucket digging out a stump. I'll admit it , the first time I was losing daylight and I couldn't see that I probably had one outer tooth on a thick douglas fir root and I reefed too hard and it broke off. No problem, I figured it was luck of the draw and I replaced the tooth the next day. I decided that I can live with the stump, I'll saw some vertical slices and break it down to just below ground level and cover it with soil. Anyhow, after I managed to peel of the first section I set the bucket on the next cut and as I extended the bucket to get a better bite on it I broke the other outer tooth. This time I exerted moderate pressure. I realize that these teeth are hardened for trenching in rocky ground, not logging and my tractor isn't a 580. I'm just curious if any of you guys have encountered this situation or if I'm being abusive to my equipment.
/ Another broken tooth #2
Is the bucket a <font color="orange"> Kubota </font>. My dealer says the buckets for my 4690 is same as ones used on <font color="orange"> Kubota </font> Compact Excavators.
The B75 has about 500 lbs added digging force over the 4690. It's rating is very close to the Compact Excavators.
I have seen on TBN, where some owners have buckets from different manufactures.
/ Another broken tooth #3
plants; This is a guy that's broken teeth off 555's and 580's. Each time it was done digging out stumps. The worse part at those times was finding the tooth and a welder at the same time. Ofcourse, I'm also the guy that can stick a D8, and even have a stump stop said D8 in it's tracks. Thats where I learned about seatbelts. /forums/images/graemlins/blush.gif /forums/images/graemlins/smirk.gif
I never heard that the hoe wasn't designed to dig stumps. They seem to work pretty good for that. Seems like it would depend more on weld quality than you abusing the machine. Hope that makes you feel better. /forums/images/graemlins/grin.gif
/ Another broken tooth #4
Breaking teeth of a backhoe bucket on a small tractor just does not seem right to me.
I would be asking my dealer to replace the bucket and to send it back to Kubota for evaluation if it were happening to me.
Somehow I just don't see how I could abuse the bucket on my BL4690 backhoe to knock teet off. Actually, I think I have tried a time or two with no luck... /forums/images/graemlins/blush.gif
The BH75 certainly is not a heavyweight hoe.
I don't know about the teeth on your bucket though. Are they the kind that have the teeth loose on the shanks, sort of crimped on? My bucket teeth are welded [don't know why I said welded, I knew they were bolted] on solid. Are you losing the whole tooth, with the shank being torn off the bucket?
Could you post a picture?
/ Another broken tooth #5
Henro ,
I can break the teeth off any bucket and any hoe I want digging out a stump . It is all in the "compounding of the hydraulics" . If you can get the teeth wedged into the stump , curl the bucket when the back of the bucket it is against something solid you will break the tooth or worst . I have done this on full size hoes and CUT's of all brands . Doesn't matter .
Big Al
/ Another broken tooth #6
<font color="blue">Henro ,
I can break the teeth off any bucket and any hoe I want digging out a stump . </font>
BigAl, I guess I will have to concede that you are a better man than I am... /forums/images/graemlins/grin.gif
If you lived near by, I'd invite you over to break a tooth off one of my buckets...just to learn something, if nothing else... /forums/images/graemlins/grin.gif /forums/images/graemlins/blush.gif I really don't think these little backhoes are that strong. I've been wrong before though...
Hey, maybe you do live close...I'll have to check after posting this... /forums/images/graemlins/smile.gif /forums/images/graemlins/shocked.gif
/ Another broken tooth #7
I too, have broken teeth of off of a compact hoe. I think the count is four now. I have been changing the shanks out for a different design as I break them off. No more broken shanks with the new style.
/ Another broken tooth #8
Here is a pic of what the teeth on my Kubota bucket look like. They seem to be pretty well made and pretty strong. I don't remember reading even once here at TBN about Kubota buckets loosing their teeth. That doesn't meant it has not been reported a dozen times, just don't remember hearing of it...
Plants4u has the newer Kubota backhoe, the BH75. Don't know if it shares the same bucket design, or if it has a new design of some kind.
Anyway, I thought a picture of what the buckets supplied with my BL4690 look like might be of interest. Both share the same tooth design, and both seem very durable, but I could just be guilty of babying my tools (no toys around this house if the wife is within a hundred yards! /forums/images/graemlins/grin.gif )
I have never given second thought to prying, banging rocks to break them loose, or whatever...now you guys got me worrying... /forums/images/graemlins/blush.gif
Henro, here are some pix of the broken teeth you wanted check out.
pic 2
/ Another broken tooth #12
Looks like some kind of cheap cast steel instead of the forged ones like on my buckets! /forums/images/graemlins/shocked.gif
(Just joking...I'll probably lose half of mine next time I put the hoe on... /forums/images/graemlins/blush.gif /forums/images/graemlins/frown.gif )
/ Another broken tooth #13
I didn't know that your backhoe had that design. You shouldn't have had any problem with them breaking the way they did. I would venture a guess that there was a manufacturing defect. The ones that I was referring to was weld on shanks without a secondary lip to reinforce the shank with pin on teeth.
Well Henro, when I saw how the inner steel looked I thought cheap casts also. Boy I hate to use Kubota and cheap in the same sentence.
I guess I'll have to put my brief stint as a logger on hold until I can find some better teeth for the hoe.
I bougth my local dealers last one in stock, but I ordered a few from Tractorsmart. I'll be set for at least another week!
/ Another broken tooth #15
ok,ok ! /forums/images/graemlins/blush.gif I stand before you a humble man . It does look like a design or manufacturing flaw to me too . /forums/images/graemlins/frown.gif I think Kubota should stand behind them on warranty .
Big Al
/ Another broken tooth #16
If this was a L3130 I'd say it was normal! Poor quality..... /forums/images/graemlins/cool.gif
/ Another broken tooth #17
<font color="blue"> If this was a L3130 I'd say it was normal! Poor quality..... </font>
Ramon49,
Poor quality? /forums/images/graemlins/confused.gif
I know you have been a solo whining voice with respect to poor power on the l3130... /forums/images/graemlins/shocked.gif
Are you changing your tune now? /forums/images/graemlins/crazy.gif
I know this is a tired subject but what do you guys think of this ? Compare the tooth placement on the center tooth and the outer ones. There is quite a gap between tooth and bucket edge.
I suppose a guy could drill new holes and get a better fit, and maybe less strain on the outer teeth.
/ Another broken tooth #19
Plants4u,
Keep in mind that it is the nature of the beast that when the tooth on the outside is angled, there will be a space on the inside like shown in your photo.
I don't have a photo handy showing what it is like on my buckets. I would not be surprised if it was similar to the photo you posted. I will try to remember to take a look and even take a photo of what mine are like.
But I would not expect them to be too different from your photo. Only because a fit that is tight when not angled, will open on one side when angled...
/ Another broken tooth #20
Just a thought, not to any one person. The angle of the outside teeth seem to be to much. If it was reduced the same goal would be achieved without as much side load on the teeth.
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
High Hood All Aluminum Timpte 720 Trailer (A63689)
High Hood All...
2006 CHEVROLET 2500 SERVICE TRUCK (A63291)
2006 CHEVROLET...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A63291)
KNOW BEFORE YOU...
2022 FORD F-750 SUPER DUTY DUMP TRUCK (A63276)
2022 FORD F-750...
2018 Regal 29OBX 29ft Boat with 34ft T/A Boat Trailer (A61569)
2018 Regal 29OBX...
