Another 4310 battery question!!
/ Another 4310 battery question!!
Talked with the dealer last Friday. He wants me to bring it in so they can have a look at it. I won't be able to bring it until this coming Friday. Hopefully it will get taken care of with minimal hassel.
Called dealer today to check on the status of my tractor. They are going to put vent tubes on battery and run them under tractor so any venting will be away from oil cooler. They are also going to "clean-up" any existing corrosion and make a note in their computer system in case that becomes an issue in the future. Dealer thinks there is only minor corrosion to some of the cooling "fins". I don't know if there is a better word for that or not. /forums/images/graemlins/confused.gif
I think I should be satisfied with this fix unless there is something I am missing.
/ Another 4310 battery question!! #25
I live in bryan Tx,and have a 3320 I am trying to clean up 20 acres with,what part of the county are you in. kenwyatt3102@yahoo.cpm
/ Another 4310 battery question!! #26
/ Another 4310 battery question!! #27
I had my oiler cooler blow a serious hole because of the battery corrosion. The dealer replaced my cooler and put a sealed battery in my 4300. All done under warranty. No cost out of my pocket. /forums/images/graemlins/cool.gif
/ Another 4310 battery question!! #28
I think it may come to that if I have a problem in the future with the cooler. Hopefully they are right in saying that it looks to be only minor surface damage.
/ Another 4310 battery question!! #31
Minor surgery = the kind done on YOU.
Major surgery = any procedure done on ME.
Just kiddin' They will take care of you!
/ Another 4310 battery question!! #32
I got my tractor back on Friday (two weeks after I brought it in!). They cleaned up the cooler fins and repainted it, put a new battery in with the vent cap on it. One of the mechanics told me that they tried to put the vent cap on my original battery but it was a fairly loose fit. It fits more snug on the new one but I can easily remove it with figure pressure. He advised me that this may not work but it is what John Deere had told them to do. I mentioned to him that I thought a sealed battery was the best fix and he agreed. He said they could not find a part number for this /forums/images/graemlins/confused.gif. I told him I would watch how this "fix" worked and let them know if I have problems. I am glad they did something but honestly I feel they should have found a sealed battery, put that in and been done with it. They had already decided to put a new battery in, why not look harder for a sealed one. Maybe I will be surprised and all will work out fine.
Anyone else have any experience with this vent cap being not a firm fit with out problems?
/ Another 4310 battery question!! #34
/ Another 4310 battery question!! #35
On my JD 4300 of 1998, am still on the 3rd JD battery. Lot of cold starts through the winter months.
/ Another 4310 battery question!! #36
I've had problems with battery's on my 4410. I solved the issue by not stopping and starting my tractor as frequently. Especially on the first start of the day. To me it seems like the alternator is marginal on these models and after you start the tractor you need to let it run for a while to recharge the battery. Since I've been doing this I haven't had any battery problems. If I had a do over I would have ordered the heavy duty alternator when specking out the tractor. If I ever need to replace the alternator.....
/ Another 4310 battery question!! #37
I've never had a problem with charging or starting, except when the batteries are at the end of their lives.
/ Another 4310 battery question!! #38
That's been the problem. Everything else I own I usually get at least 6-8 years out of a battery. Most times more like 10-12 years. My 4410 in the early years before I caught on was like 2-3 years
/ Another 4310 battery question!! #39
I wonder if you have problems with your alternator? I've never had a lead/acid battery last more than maybe 5 or 6 years. I think the heat down here kills them.
Full disclosure, I initially tried to order this battery from Rural King badged with their name. I did not get a confirmation or anything for a few days and I called and they said "Oh, we don't have any in the warehouse, so we were going to cancel your order." Well, I'm sitting here expecting it to show up and wasted about 3 days. I don't think they'd have called me or emailed me at all....They said it only showed inventory in some stores, and they had the best price of about $127 IIRC.
/ Another 4310 battery question!! #40
And the Strongbox from Deere is $139 ??
2014 Link-Belt 350X4 Hydraulic Excavator (A61572)
2014 Link-Belt...
2023 John Deere 8R 310 Tractor (A63111)
2023 John Deere 8R...
2016 Cadillac CTS Sedan (A61574)
2016 Cadillac CTS...
UNUSED WOLVERINE BUCKET (A64281)
UNUSED WOLVERINE...
UNUSED ATS POWER ATS-GAC40Y 40 GALLON (A64281)
UNUSED ATS POWER...
More info coming soon (A61569)
More info coming...
