An EV??????`
Status
Not open for further replies.
/ An EV??????` #221
This thinking is still baffling to me.
Do I really need to go buy an EV, trailer it home (since I know it won't make it on its own) just to be able to partake in the discussion?
Yes, it could be used to go to the post office, the nearest voting place, and the gravel pit. And the neighbors, of course. Basically, maybe 50 miles per year.
That'd be a very expensive way to have a voice that's apparently not covered by the First Amendment in your world.
There is so much misinformation spread on these posts by people who don't own EV's.
Once you own one you understand why it is misinformation. Why offer an opinion on something you don't own?
That is like talking about the problems with tractors without owning one. You would be laughed off of this forum.
/ An EV??????` #222
I keep hearing about the high insurance rates for EV’s and that some insurers won’t write a policy for EV’s. Is this true and what is the comparison for insurance costs for ICE and an EV.
I think it depends.
My first EV was a Ford Ranger converted to Lead Acid batteries in a small commercial shop. I think State Farm refused to insure it due to the conversion, but Progressive did.
My second EV is the Azure (Ford) Transit Connect. Progressive deemed it as a commercial vehicle, and wouldn't insure it, even though it is like a mini pickup, much easier to drive than my larger RAM 1500. Safeco wrote a policy. A small bump in the insurance cost. The insurance company deemed that I'd be driving the wheels off of it. Still, the rate is within reason.
I have liability only on all my vehicles.
How about pulling 10,000 lbs?
Most of the EV pickups available in the USA are rated to pull around 10K give or take a little bit. Rivian, Hummer EV, Ford Lightning EV, Tesla Cybertruck, and Chevy Silverado EV. The Rivian is by far the smallest of the group. However, the heavy low mass of the battery pack is supposed to give them exceptional stability. The Hummer may be the largest EV pickup on the market, and for some reason only is rated at 8,500. Probably taking more power to move it.
Most people travel less than 50 miles per day and charge at home...Right?
Most commuting is somewhere around 50 miles a day, at least in the cities. And the miles rack up. Commuting 100+ daily miles in traffic jams is pretty miserable.
My Transit Connect with an 80 mile maximum range does pretty well for trips around town, and from my place to Mom's place on opposite sides of the city (both out of town).
The problem is the occasional "road trip" where one decides to hop in the car or pickup and drive 500 miles. The decade old Transit Connect has the nearly obsolete J1772 charging which limits it to mostly around town.
Virtually all new vehicles have some kind of super charging capabilities which can get one in and out in about a half hour. Still, that isn't needed a lot.
Most people tow at least 10,000 lbs within 50 miles? Why are you being so obtuse?
The dual- and tri-motor Cybertrucks have a maximum towing capacity of 11,000 pounds
Yes, but for 80 miles before needing a charge.
It depends. A lot of towing will be somewhat close to one's home. I've been hitting a few auctions, but I prefer to stay within 100 miles or so each way. Trips to Home depot? Hauling your tractor to the shop, or to the neighbor's property?
That only breaks down when hauling your 50 foot travel trailer across the country. But, even with that, if you're planning to camp for a few days, hopefully you can get a good 220V connection and recharge in the campground.
Everything I've seen indicates that the towing range cuts the rated range down by about 50%. That certainly would depend on what one's towing. My observations with my RAM 1500 is similar. Empty I can get slightly above 20 MPG. Or, on a good day around 25 MPG. Towing, it depends on the load, but I am often in the 15/16 MPG range, and on occasion drop down to around 13 MPG. I.E. More filling stops.
The key word is If my diesel engine implodes. I will probably get 400,000 miles or more out of my diesel engine and it’s a guarantee that you will replace your costly batteries at least once if not more and I will still be driving my Cummins. There is no way your EV batteries will last as long as my diesel, no way. So yes, you will be forking over $1000’s for new batteries and I will still be racking up miles on my diesel ICE.
Perhaps.
Or you could throw a rod through the block, and start hunting for a $5K to $10K replacement engine.
400,000 miles? How many MPGs are you talking? 10? 15? Again that depends on how you're using it. But, at 10 MPG, you get 40,000 gallons of fuel which won't exactly be free. At $4 per gallon, that comes up to $160,000 in fuel costs.
Plus, an oil change every 5,000 to 10,000 miles. So, at 5K, you get 80 oil changes. How much per oil change? $50? So, an additional $4,000 or so for oil changes.
Did you blow up a transmission too?
Your EV pickup won't exactly be free to operate. Currently home charging is much less expensive than gasoline or diesel. Supercharging on road trips is about equivalent in cost to gas or diesel.
We'll see how the technology shakes out over the next few years, but a lot of this seems to be fear mongering.
While I do have the EV Transit Connect, a larger EV pickup doesn't fit my needs at the moment, but I'll probably have one within 5 years.
/ An EV??????` #223
As someone pointed out earlier in this thread, you don't have to own an EV to know about their pros and cons.
The manufacturers' (somewhat inflated and misleading) range estimates are readily available, as is the locations for charging. Also, when a dealer is honest enough to say "don't buy one" when they could potentially sell a $100K to $230K EV, there must be a reason they'd rather not.
Besides, scientists don't own the moon, for example, yet can freely discuss their findings and opinions about it. Trying to exclude certain peoples' opinion is unfortunately becoming common, but that doesn't make it right.
/ An EV??????` #224
I think it depends.
Watch Youtube videos on real world tests of pulling weight behind an EV pickup. I believe it was less than 100 miles until the charge hit 0%.
Not good enough for my needs. I would love to get rid of my diesel truck and get another Tesla but just can't do it at this point.
I had to make four 50 mile round trips in one morning getting 7k lbs each of paver base, sand, pavers pulling a dump bed trailer. Could only do that with my diesel truck and not an EV truck.
BUT, now that I have my Tesla I use that for everything else which is 95% of monthly driving. I suspect for most that would be the same.
/ An EV??????` #225
A friend of mine puts around 400,000 miles on his Ram in about three years or so, delivering trailers. Sometimes grossing out at a bit over 45,000 lbs.
He gets a bit over 10 mpg on average, partially because he generally bobtails back. Yes, he pays dearly for fuel, but makes a really good living doing his job.
Other than basic maintenance (oil changes every 15,000 miles, which he does himself) he has had minimal issues. Part of that is by trading them in at around 400,000 miles or a bit more.
/ An EV??????` #226
I have never worried about warranties as I don't want others to work on my vehicles, so I don't know what time or mileage they cover. If I did worry about it, I'd get extended warranties.
And maybe I'm alowed a tiny bit of input here if I admit that I own a John Deere eGator? It never leaves the property, so worst case would be that I had to walk half a mile.
Our eEzgo is our most used hauler on the place.
/ An EV??????` #227
I'll rewatch some of the review tests. What I've seen in the past was that hard towing was about 50% of the rated range. So, if rated at 400 miles, then towing would be about 200 miles. But it all depends on what one is towing.
Your dump trailer would be wide which is a problem for aerodynamics, but it would be relatively low, so it may not be as bad as one expects. Also half the drive is empty (but not as short as a flatbed).
Keep in mind that the Tesla Cybertruck went almost 4 years from announcement to delivery. In that time it has already become obsolete.
The king of the hill for towing is probably the Silverado EV, and I expect more good things from that one in the near future. We'll see what RAM comes up with.
Anyway, if you do 4, 50 mile RT trips towing may be pushing the EV battery capacity a bit, but it may do it. How often do you do that? Do you have charging at the destination? Is there a supercharger somewhere that you could top off on one of the trips (assuming you can get your pickup and trailer to the charger)? You'd probably only need about a half a charge.
I do a fair amount of freeway driving for my long hauls. So, surely there is a place to recharge almost everywhere I go. The worst is the hop from Eugene to Bend to Ontario to Boise. How many extra stops due to a paucity of chargers? What if I was counting on a single charger in Burns, and there was none? Yet those charging deserts will be solved eventually.
/ An EV??????` #228
Have you seen the videos of people gassing up a boat and mistakenly pumping the fuel into a gunwale rod holder or downrigger mount? The fuel is either pouring out the drain plug hole or filling up the bilge. I've seen where they've pumped hundreds of dollars' worth of fuel.
/ An EV??????` #229
That JD is probably what I use the least around here. But it's a practical dinghy once I made a towbar for it.
That way I can quickly go back and pickup up whatever tools and such I might need where I'm working.
For the very most part it's a Dihatsu HiJet that gets driven the most - about 10 miles per week on average. The tiny tank lasts me for months.
/ An EV??????` #230
For the very most part it's a Dihatsu HiJet that gets driven the most - about 10 miles per week on average. The tiny tank lasts me for months.View attachment 861319
That's one nice machine.
Our golf cart is DC but has Regen feature and a safety feature that locks the rotor for 2 seconds over and over if you just get off without locking the brakes and it starts to roll off.. Our place is very hilly the and the kids were like 12 when I got the cart to use around the place and for driver Ed training. The son and daughter are twins and we had 10 miles of county roads for training. When a driving infraction occurred they had to swap places.
The partial eclipses is in progress locally so that is cool.
/ An EV??????` #231
I had the trailer home the 2016 Leaf SL because the closest one I could find that I liked was in St. Louis Missouri which is 200 mi and the battery was compromised. Instead of having the new range of 105 miles it was down to 60 mi or 40 mi on the interstate. Thankfully 5 weeks after getting it it triggered the warranty and Nissan no longer had the 30 KW hour battery and had to replace it with a 40 giving me 150 mi of range. So for $13.5K I had a new like 25K mile EV with a new 202O 40 kWh battery with a heat pump which wasn't a Tesla option when the Leaf was new. The Leaf got totalled eight months after getting the new traction battery.
I was planning to sell it after getting the Tesla in January of 2023 but decided to keep it since the battery is holding up so well and my wife drives it on days that I cannot take her to work.
Round trip to work for her is 30 mi and the 150 mile range is an ideal car for local use. After driving the model Y for 27,000 mi. I'm glad my son talked me into getting it. The artificial intelligent version of FSD that came last week is awesome after using version 11 of FSD for the prior 14 months.
The kids are finishing up college and one will be 8 hours away round trip and the other one 16 hours round trip. So we needed a long distance option and the Tesla does a good job for Cross country trips. The longest trip I've taken so far to Austin, Texas which was about 24 hours round trip. Not having to look for chargers is a big plus when owning a Tesla.
/ An EV??????` #232
What the wealthy drive is of little consequence to the market.
Seeing a larger proportion of EVs in those areas does not mean much. It also feeds the "toys for the rich" narrative. These are not the folks that keep a vehicle for more than 5 years like most of us do. When the new wears off, they buy the next new toy to feed their egos.
Hey... I was driving a 2011 Corolla... newest car in my fleet.
I still have cars I bought 50 years ago...
/ An EV??????` #234
When you own an EV you will have the light bulb moments of "Ahhhhh...now I see what they were talking about". ;)
When did I say you are not covered by the 1st amendment?
/ An EV??????` #235
Well, I have been told that unless I own an EV I have no idea what they're like, and shouldn't have an opinion about them. Or at least, if do have one I shouldn't post it here.
And while I may be stupid, I'm smart enough to know that an EV wouldn't work for my usage. There's no need to buy one just to prove the obvious. I do know what you're talking about, but that doesn't make an EV any more practical for me.
Sure, I could get one to go to the post office with, but at this point I'm trying to sell off a few vehicles, not buy more.
Ideally I'd like to put some miles on the truly fun-to-drive vehicles I have, instead of buying new tires to replace aged out ones, and putting Star Tron in the tanks because they've been sitting for over six months.
/ An EV??????` #236
"When you own an EV you will have the light bulb moments of "Ahhhhh...now I see what they were talking about". "
Crack addicts say the same thing, but I'm never going to try it!
/ An EV??????` #238
Ok, so a number of internet channels have tried to do EV pickup test "experiments".
Rather long winded, but a good comparison between models.
So, gasoline pickups (F150/1500 models) get as low as half the rated MPG when towing heavy bulky loads. And the same goes for the EV pickups.
Ok, a theoretical discussion about pickups, EVs, and towing.
What Semi Trucks have figured out. Reduce gaps and turbulence between the cab and the trailer. Enclosed teardrops?
If an EV pickup is rated for a 300 mile range empty, then half that gives about 150 miles of hard towing.
Likewise, if the EV pickup is rated for 450 miles empty (Chevy Silverado with largest battery), then half that gives about 225 miles of hard towing.
I tow with my flatbed, and RAM 1500. The flatbed isn't light. However, most of my towing will be empty one direction and loaded the other direction. On a good day, I get about 25 MPG with the RAM empty. 20 MPG with the trailer empty, and 13 to 16 MPG with the trailer loaded.
The same thing would surely apply to an EV such as the Silverado EV. 450 miles empty without a trailer. I'd hope to get 350 miles or so with the flatbed empty, and then 200+ miles with it full. So, a trip like today, just shy of 200 miles RT should be well within the range of the Silverado since half the trip was pulling an empty trailer. On the other hand, a trip to Seattle (just shy of 600 miles RT), and I should be able to get to Seattle on a single charge. Then get recharged in Seattle and somewhere around Portland on the return trip.
Now, keep in mind that the EV companies are working on getting rapid charge times down, and one wouldn't necessarily have to do a full charge. 80% or 90%? With some luck, that trip to Seattle would have two half hour rapid charges.
Or... I don't like to do my Seattle trips without stopping somewhere for at least 4 or 5 hours resting. So, I wouldn't need 350 KW charging all the time. A 50 KW charge for about 5 hours would be plenty. If only they put some chargers in rest areas so one could hook up and take a nap. Then again, there is the problem with rest areas never having enough capacity at night for trucks and trailers, and EV charging could be worse.
/ An EV??????` #239
What is the cost of installing a new 200A service (or larger)?
I'm seeing estimates of $1000 to $2000 or so.
Your numbers look too low to me for a legitimate professional 200 amp conversion, for a complete job.
Realistically pricing would be about double your numbers
/ An EV??????` #240
Sort of like a mini “cancel culture” right here in this thread.
Status
AIM 5' Rake (A64911)
2004 CHEVROLET MALIBU 4 DOOR CAR (A66091)
2004 CHEVROLET...
x (A68191)
x (A68191)
2018 Chevrolet Suburban 4x4 SUV (A66738)
2018 Chevrolet...
2024 Kubota SVL75-3 (A64911)
2024 Kubota...
2009 FORD E350 CARGO VAN (A66091)
2009 FORD E350...
