Oil & Fuel Am I reading the manual right?
   / Am I reading the manual right? #11
I just read through my manual yesterday and it said every 50 hours. I'll double check but when I looked at the maintenance schedule at the top it said 50 with the little symbol that described as "every". I'll have to look again I think it said further in the print to change every 50 as well. When we were putting 50 hours/week on the state tractors we were changing oil every 2 weeks. These were hard hours mowing tall orchards and vineyards at 540 PTO rpm for 10 hours/day.
If that was in NY they must have been running two shifts of drivers.
   / Am I reading the manual right? #12
Owner's manual for my Kubota M7060 says oil change every 500 hours. I change it once a year which is about 140 hours.
   / Am I reading the manual right? #13
Is really 250 hours between engine oil changes that much time?
On my Branson, the manual says 250 hours. I have about 130 hours on the oil now, it barely changed color so far. On the 50 hours maintenance the oil was still as clear as if they had it changed 5 min before. I'm planning on following the manual.
   / Am I reading the manual right? #14
O.T. for Cornell University it was 15 years ago now. 60hr. Work week 5-5. Made good pay just for being summer help.
   / Am I reading the manual right? #15
I did mine at 50. I plan on doing it again at 250, not 50 + 250. Then I'll see after that.
   / Am I reading the manual right? #16
FWIW I did check my manual and after the 1st 50hr service it is at 300 hrs. This is the MT2xx manual. JPEG_20200121_185602_4579268354993984839.jpg
   / Am I reading the manual right? #17
I like to change mine every 100 hours, because like you I thought that was way too long between them. Unlike so many who say fall, in the winter, with warming and cooling days, condensation can form on the INSIDE of the tanks, mixing moisture with the oil, so I like to change mine in the spring once it's warming up enough at night not to cause so much condensation. Had an "old timer" tractor mechanic tell me this years ago, sounded good enough for me
   / Am I reading the manual right? #18
Changed at 50, but will do subsequent changes every 100. That works out to about once a year for me, maybe a little shorter. Owners manual shows every 200 hrs.
   / Am I reading the manual right? #19
First year owning my B2650. First winter. Should I be firing it up now an again throughout the winter, or can I leave it sit? Harm either way??
I have a battery tender on mine to keep it fresh, but I don't start it unless I'm going to use it. The only thing you might see if you don't use it is critters making nests in your wiring or air cleaner. That could potentially happen at any time though.
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
KOMATSU WA270 (A58214)
2020 CATERPILLAR 289D3 SKID STEER (A60429)
2020 CATERPILLAR...
2017 FORD E-350 SUPER DUTY 16' BOX TRUCK (A60430)
2017 FORD E-350...
2012 DOOSAN G25KW GENERATOR (A55745)
2012 DOOSAN G25KW...
Kubota SVL 75-2 (A60462)
Kubota SVL 75-2...
