Alternator/battery question
   / Alternator/battery question #11
hmm.. that mf 1010 is an early to mid 80's to mid 90's tractor with a toyosha diesel.. about 16hp if I recall correctly. not sure what method of fuel stop it has.. pull cable or solenoid. it didn't sound like he talked to a dealer service tech who told him to th do the cable test ( not one i would do ).. sounded like someone at an auto/electric shop.. so.. to the OP.. does it have a fuel stop solenoid, or a pull to kill cable, or do you dump the throttle to kill it?
soundguy
   / Alternator/battery question #12
You said you checked the belt ... but, did you check the wire connections. You may have a lose connection on one of the wires.
That said, I suspect a bad alternator.
   / Alternator/battery question #13
No idea how the MF1010 fuel shutoff works, I was speaking in general...
I'd not necessarily trust the auto store battery testers, I had problems with my Case - wouldn't seem to hold a charge. I checked the alternator (using a multimeter!) and that seemed ok, So I took out the battery and had it tested, they said it was fine. That just didn't seem right, so I temporarily put a different (much smaller, as that was all I had) battery in and no more issues. Bought a new battery and no problems since.
But having said that, if the alternator voltage measurements listed above are correct, I'd suspect the alternator...
   / Alternator/battery question #14
I heard that. had a bettery dieing issue in my wifes yukon.. MM showed correct alt voltage .. battery was under warranty, and I took it in to the store I bought it from and they tested it. first test failed as battery was discharged ( did it overnight ).. they had to keep it, charge it al lday then retest.. tested ok. ( was a 3yr battery with a few months of warranty left.. ie.. near 3ys old. apparrently on their chart, it can test at 80% of it's rated output at that age and be ok ).. in any case.. it did it again the next weekend, 3 times in all, I had the battery back to the store. got good at taking it out :( they had me bring in her truck to test votlage of charge system. I used a spare tractor battery I had.. an interstate, in her truck during the 'week' that her battery was failing / being tested. I mentioned that her truck was running fine on the spare, and didn't kill it overnight like the other one. finally after 3 testings, and dieing 3 times, It kept testing right at the 80% it needed to pass.. I think the guy either fudged it to 79% to fail it.. or it actually hit 79% on the final test and they replaced it under warranty.. or at least.. gave me the pro-rated credit if I would buy another battery from them :) which i did. was simply cheaper than buying another somewhere else. In the end, i used their 'cheap' battery as my tractor battery and kept the interstate in her yukon.. :) both are doing fine..
soundguy
   / Alternator/battery question #15
Okay so Now you can see how well the cheap battery holds up to vibration and sitting in tractor?
   / Alternator/battery question #16
it's actually the 'spare' tractor battery. IE.. not in use
If the tractor is a diesel with a manual shutoff, it'll most likely keep running even if you pull off the battery cable... ;)
Ha funny. I reopened this thread at page two, to find you guys talking about the fuel shutoff. I was thinkin "what the heck does that have to do with the battery?", so I went back to page one, and now I know:thumbsup:. Yes it IS manual, cable, fuel shut off, so I guess that test was a waste of time. not sure if I mentioned it was a tractor to the guy or not. The tractor is a 97 I believe, with a 16hp 3 cyl diesel.
This wasn't an auto parts store, it was just a battery shop, so I would HOPE he knew what he was doing when he tested it, and yes, the battery HAD just come off an overnight trickle charge.
So far it has started the last two days, but the light seems to still come on more than it ever used to, or at least that I notice anyway.
I did NOT check the connection, believe it or not but I sure will very soon.
Will be going into town today, so I will call around to find someone to test it, and hopefully have a replacement, if needed.
I will post. Keep the ideas comin though.
   / Alternator/battery question #18
94 should have been the last year of manufacturer.. but then.. I'm not a MF expert either.. :)
   / Alternator/battery question #19
Sounds like you have a diode going out. Hard to find, have to take the alt apart, and test each one. And as is intermittent may make it a lot harder.
   / Alternator/battery question #20
Back in the age of cars that needed constant maintenance I came to know the HTFCS (holy trinity of the failing charging system): battery, alternator, voltage regulator. Do tractors use a voltage regulator?
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51219)
2019 INTERNATIONAL...
Unused 2025 CFG QK20R Mini Excavator (A49461)
Unused 2025 CFG...
1993 Mono Dump Trailer (A50514)
1993 Mono Dump...
2009 FREIGHTLINER CASCADIA SLEEPER (A51222)
2009 FREIGHTLINER...
2018 Toyota RAV4 SUV (A50324)
2018 Toyota RAV4...
1989 SHOPBUILT THREE AXLE LOWBOY TRAILER (A50854)
1989 SHOPBUILT...
