Ballast almost flipped the tractor, really need some help!
/ almost flipped the tractor, really need some help! #121
For sure.
It was knealing and going to roll but the width/weight of the bucket may have become a positive at that point.
I am shocked if the dealer did not get the OP to sign a statement that NO FEL should be used on a naked tractor without proper ballast.
/ almost flipped the tractor, really need some help! #122
Unbelievable what some people have done to this thread and the OP:mad:
Thingyy42, please check your PM's...
Ahh sorry for all the confusion! ill explain better!
the strap holding the machine in the spectacular position is not exactly the normal configuration. That was added at some point...and it is under tension.
I added the purple strap after, the strap is actually tied around the garage wall! I was hoping if the front of the tractor did slip the strap would hold it in place and prevent it rolling over to the left, or better yet of it did slip the strap would hold the back in place so it would naturally be lowered.
Fifth, FELs do not "arrive," they are installed and if you have the lack of background you say you do, then you certainly did not install it.
sorry for the confusion here, i didnt install the FEL yes. There was a delay of about a month and a half from when i purchased the tractor and when the FEL arrived, i say arrived because it had to be shipped from Melbourne to sydney. The state i live in issued a new law saying that all new front end loaders must be self leveling and because of that i had to wait for a self leveling loader to be shipped to me. The deere guys took the tractor the day before and the tractor with the FEL had only arrived that day.
Sixth, the path through the cut down area is fairly well packed by tractor tires both above and below the location of the machine in the photos. You were up and down through there several times
I had been down that path many times! I cut it out using the 5ft grader blade (hence the 1ft discrepancy with the loader) . It was pretty easy to drive the tractor up and down that slope and it compacted over the weeks i had to use it before the loader arrived
I will put more photos up!
you can all have a laugh at the tow guy lowering the tractor! I wish i had the skills to stage this!
/ almost flipped the tractor, really need some help! #124
Another angle...
What we have here, is the teeter totter factor. Simple physics.
/ almost flipped the tractor, really need some help! #125
It's easy to get a tractor on 3 or 2 wheels. I'm moving a heavy sweeper and have nothing on the back.
2nd picture is me lifting the back of my tractor off the ground with a load of gravel in the bucket. The L35 model is very heavy on the front end when the backhoe isn't on the back.
/ almost flipped the tractor, really need some help! #127
Hi thinggy42.
I live in the same state.
This might be a dumb question, but what does a self levelling loader do that a non self levelling loader doesn't? Which bit self levels? Is it that the bucket maintains it's position relative to the horizontal plane as the loader is lifted?
Regards,
Ian S.
/ almost flipped the tractor, really need some help! #128
Betya is has everything to do w/ guys lifting stuff and it rolling BACKWARDS out of teh FEL bucket then onto the tractor in close proxmity
to or ON THE DRIVER.
/ almost flipped the tractor, really need some help! #129
Gudday Ian, I think you're right about the bucket maintaining it's position relative to the ground.
/ almost flipped the tractor, really need some help! #130
Yep, self-leveling loaders can keep the bottom of the bucket level with the ground. Many of them look like they have an extra set of arms running along the loader frame -- much like articulated windshield wipers that maintain an angle. Remember the old days when windshield wipers didn't do that ?
You select a "curl" angle (angle of tilt of the bucket) with normal bucket joystick controls and then that angle with the ground is maintained as you raise/lower the bucket.
I do not personally see that as being of any safety value and it is downright scary to see governments requiring it. What will they require next ?
/ almost flipped the tractor, really need some help! #131
I did similar "acrobatics" like thinggy42 with a skid loader. I just rented the machine and tried to get feel for it so I tried different thing like lift and lower the bucket, go forward and reverse etc. One time I moved forward when the bucket was lifted and when I stopped the skid loader fell on its nose. I was just hanging in the cab on the seat belt unable to reach pedals to lower the bucket and set the machine on all four wheels. It is the momentum of the bucket that rotates the machine forward when in stops. Tractor can also fall on its side because as the rear wheels lift from ground the tractor rotates side ways on the pivot of the front axle.
/ almost flipped the tractor, really need some help! #132
2X on the remark about governments taking such action. One could expect it was funded by one who sold the feature and the competitor did not have the feature.
/ almost flipped the tractor, really need some help! #133
FunnelWeb - Does your tractor have a warning like mine showing a round bale rolling out of the bucket and onto the operator when fully raised? Could be a reason for requiring a self leveling bucket. I had a load slide back unexpectedly on me last week when I had my pallet forks on and was lifting a tub of liquid. Visibility to the forks isn't too good and I hadn't seen how quickly the angle was changing. The worst part about it was the dirty look my wife gave me, like what were you thinking anyway?
Thinggy42 - I am sure you shut down right away and your friend probably set it back down without starting the engine but there were a couple posts estimating the tractor angle at 44 to 53 degrees. The Cat engines we use in our product line have a normal limit of 35 degrees in any direction. Your oil pump inlet probably was out of the oil fr a little bit until you got the engine stopped, which is not a big deal. The front cylinder, however, had to really be slamming down into a solid slug of oil. Probably not a big deal but something to remember if you start hearing odd engine noises.
/ almost flipped the tractor, really need some help! #134
I did an Internet search on the New South Wales (NSW) government requirement that front end loaders be self-levelling. I found the following document, published by the NSW government.
Front End Loaders And Their Attachments On Tractors - A guide on health and safety standards
Diagrams on pages 5 and 6 of the document compare front end loaders with and without the self-levelling (or anti-rollback) feature. A diagram on page 13 explains changes in centre of gravity when a front end loader is fitted.
/ almost flipped the tractor, really need some help! #135
Hi MHarryE,
Unfortunately I don't have a tractor at the moment. My wife and I are currently shopping around for a rural property. Once we secure a property, then I'll go shopping for a tractor. :thumbsup:
My tractor experience at this stage comes from growing up on a dairy farm. We had several different tractors over the years, but non of them had a front-end loader.
/ almost flipped the tractor, really need some help! #136
I like the self leveling feature. I think it adds to convenience and safety as well. I dropped sand, gravel and top soil on the hood of my tractor from lifted FEL few times before I got hang of it. I think most if not all FEL on large (expensive) tractors have it.
/ almost flipped the tractor, really need some help! #138
Cantoo your photos help me and I expect others relative new to FEL's to grasp one can not just bolt one on and operate the same way when all that weight was NOT there.
Our old JD 310B weights about 12K+ pounds and the tires are dry. Even with the very heavy hoe with a full bucket with a full bucket I get the sense it needs to be kept near the ground when traveling with the load.
After digging up a good size tree and pushing it over I use the FEL to roll the root wad out of the hole and often one rear wheel will lift a foot which stops the pushing/lifting effort.
/ almost flipped the tractor, really need some help! #140
You've gotten a lot of good advice. I wont add to it other then to say the views are awesome. Lovely place. Looks like a river n the valley?
I'm sure you weren't enjoying them from the elevated position of the tractor seat tho. :)
