Allmand TLB 25K (not hydraulics)
   / Allmand TLB 25K (not hydraulics)
I never had any luck requesting past quotes from AllmandtractorParts. They were never able to source the parts that I needed. I can guarantee that these are generic parts as is almost every other part on these machines. All I can suggest is spend some time, get the necessary measurements and you'll be able to source the part that you need. Good Luck
   / Allmand TLB 25K (not hydraulics) #32
Thanks. Agree I‘ll see what I can match up based on measurements, etc.. Will post when I figure it out.
   / Allmand TLB 25K (not hydraulics) #33
I had a few replied emails from allmandtractorparts go to my junk or spam inbox in the past. I sent the same parts request a few times but was never hearing anything back… or so I thought, until clearing out spam inbox a year later and realizing the reply’s just never made it to my regular inbox.
You were looking for tie rod ends as well. Did you ever find a solution?
   / Allmand TLB 25K (not hydraulics) #35
Moog es2171 is from what I have found from matching specs to be the closest match. I have not ordered or tried them yet though.
   / Allmand TLB 25K (not hydraulics) #36
Did you ever try those Moog tie rods?
   / Allmand TLB 25K (not hydraulics) #37
Haven’t yet, I just went through a bunch of fixing on other parts of the tractor so it hasn’t made it high enough up on the to do list yet. You could always pop a tie rod out and measure it up and see what you come up with. Moog has a chart with hundreds of them with all the dimensions
   / Allmand TLB 25K (not hydraulics) #38
Has anyone been able to identify the tie rod ends? I have three different ones on mine but none of the stamped/cast numbers show up on google or at the part store.
2013 freightliner Altec D2050-TR Derrick Digger Truck (A52377)
2013 freightliner...
2016 Ford F350 - Butler Bale Bed - 4WD - 125k Miles (A53473)
2016 Ford F350 -...
FORD 555B BACKHOE (A51406)
FORD 555B BACKHOE...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
22ft Rollback Flatbed Body with Winch (A54814)
22ft Rollback...
KMC 5610 LOT NUMBER 33 (A53084)
KMC 5610 LOT...
