Allmand TLB 25K (not hydraulics)
   / Allmand TLB 25K (not hydraulics)
I never had any luck requesting past quotes from AllmandtractorParts. They were never able to source the parts that I needed. I can guarantee that these are generic parts as is almost every other part on these machines. All I can suggest is spend some time, get the necessary measurements and you'll be able to source the part that you need. Good Luck
   / Allmand TLB 25K (not hydraulics) #32
Thanks. Agree I‘ll see what I can match up based on measurements, etc.. Will post when I figure it out.
   / Allmand TLB 25K (not hydraulics) #33
I had a few replied emails from allmandtractorparts go to my junk or spam inbox in the past. I sent the same parts request a few times but was never hearing anything back… or so I thought, until clearing out spam inbox a year later and realizing the reply’s just never made it to my regular inbox.
You were looking for tie rod ends as well. Did you ever find a solution?
   / Allmand TLB 25K (not hydraulics) #35
Moog es2171 is from what I have found from matching specs to be the closest match. I have not ordered or tried them yet though.
   / Allmand TLB 25K (not hydraulics) #36
Did you ever try those Moog tie rods?
   / Allmand TLB 25K (not hydraulics) #37
Haven’t yet, I just went through a bunch of fixing on other parts of the tractor so it hasn’t made it high enough up on the to do list yet. You could always pop a tie rod out and measure it up and see what you come up with. Moog has a chart with hundreds of them with all the dimensions
   / Allmand TLB 25K (not hydraulics) #38
Has anyone been able to identify the tie rod ends? I have three different ones on mine but none of the stamped/cast numbers show up on google or at the part store.
New Power Line 500 Metal 3pt. Spin Spreader (A50774)
New Power Line 500...
1997 Semi Dump Trailer (A50514)
1997 Semi Dump...
2019 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2019 UTILITY VS2RA...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51244)
(2) METAL SPOOLS...
UNUSED JCT SKID STEER QUCK ATTACH 72" BRUSH CUTTER (A51244)
UNUSED JCT SKID...
