Algae & Microbal growth in diesel
/ Algae & Microbal growth in diesel #1
big bubba
Elite Member
arkansas
M8540
recent fuel injection failure discussions on this forum have made me upgrade from Howes to Optilube. not interested in what you are using
never had a fuel problem. however, just wondering if most algae & microbal problems occur within tractor or farm storage tanks, etc
i rotate between 2x 5gal containers. i may be overthinking, just wondering your views for algae & microbal prevention in you circumstance.
i don't know compatibility of algicides & diesel fuel supplements in general but would be easy to mix... have a feeling a lot depends on how often supply is circulated. yes, am overthinking but rather that than injector pump failure, thx
/ Algae & Microbal growth in diesel #2
My thinking is...........if you are rotating just two 5 gallon containeers within a couple months of each other, you should not have an microbial growth problem....even in the heat of summer. As I understand it, Howes is just for antigel function......don't know about Optilube.
thank you on that. guess i'm looking at lubricity, water dispersion, scrubbers. haven't had to deal w/microbal & algae growth (yet), so will leave as is, thx again...in a marine location, surely would be looking at
gelling is not an issue here
/ Algae & Microbal growth in diesel #4
Once you get water in your fuel tank you have the potential for a biological growth. It doesn't matter if you rotate your fuel caddies/canisters, adding fresh fuel. The water is still in the fuel tank unless you use a biocide. Even better if you can get your hands on a biocide that breaks-down the water.
Here in Australia/NZ we have a product called "Fuel Doctors" that does this. Unfortunately it is not available in NA... unless you want to have it shipped there.
Oh, and big bubba... nice thylacine (Tasmanian Tiger) as your avatar. (y)
thank you on that. actually, did not make connection between water & biological growth. am using a capture funnel & the tractor water separator bowl seems to do a good job. again, all this is preventive as one hears injector horror stories.
& yes, what an extrodinary animal was the thylacine
/ Algae & Microbal growth in diesel #6
We have a thylacine on our Tasmania vehicle licence plates... the 'rumour' is that they are still out there in the wilds of the State.
There's even a reward for proof!
/ Algae & Microbal growth in diesel #7
Never had a problem and we use a big gravity fuel tank. Fill maybe twice a year.
/ Algae & Microbal growth in diesel #8
Brother had a problem where the filter would plug and engine quit on his daily driver 300td
Did the biocide for several months and several filter changes…
Years later he was talking to some diesel owners and they all had same issue and bought from same station.
40 years ago diesel was mostly truck stops and very few stations carried it.
/ Algae & Microbal growth in diesel #10
Algee grows mostly in the water in the fuel. Even condensation can cause water. I treat my fuel for algee when I buy it and use a golden rod filter at my hand pump. Bit useing 5gal jugs I wouldnt worry to much. Judt try to keep your machine full.
/ Algae & Microbal growth in diesel #11
We sort of discussed this elswehere but I've had first hand (expensive) experience with algae growth in diesel fuel, something I don't want to ever experience again. Had it in my diesel pickup which stays parked in the garage all winter. I keep the fuel tanks topped off in storage and I always add Power Kleen biocide to them, in fact I put it in my 500 gallon farm tank as well. In my view, if any additive claims to prevent algae growth but don't come with the Federally required MSDS labelling, it's phooey. With my truck, I did all the grunt work myself and it still cost over a grand in parts and that was 10 years ago. Probably 2 times that at today's prices. I'm pretty sure the Racor's will catch any algae, problem is, the stuff has a penchant for clogging up filters no matter what and it's nasty too.
One thing I learned and that was to stay away from any bio-diesel. That stuff is really good at growing algae.
/ Algae & Microbal growth in diesel #12
Do you think the growth came from your local fuel station in your pickup trucks case?
I think they call them SDS now but il look into what power service puts in there additive.
/ Algae & Microbal growth in diesel #13
Biobore for algae & I like optilube with some synthetic 2 stroke oil for lubricity & cetane boost. No problems in my 2011 cp 4 yet. My sailboat had a problem due to damp marine air & condensation in the diesel tank, the algae & microbes grew in the water/diesel interface layer. Biobore killed the algae, but filters kept clogging (especially when rough water bounced me around & stirred up the tank) until i went through a few tanks and a bunch of filters. I could have had the fuel polished, but didn't want to pay someone the 300 buck rate at the time to do 80 gallons & figured that since the motor only really was used for docking/departing dock, that i could polish it myself with enough filtration and extra running of engine while underway. I sucked out the water in the bottom of the tank with a diaphram pump, but the dead critters were in the fuel once the water was gone. Always kept spare racor filters on board and used vacuum gauges on the filter housings to gauge level of plugging. 2 racor 500s in series 10 then 2 micron kept the perkins on engine filters clean which was good as the secondary on engine was a royal pain to change & bleed. Changed filter elements at the rate of 2 or 3 10 mic for every 2 mic for about a year, and always had a full 2 gal jug of fresh diesel to minimize bleeding when filters got changed.
/ Algae & Microbal growth in diesel #14
Powerservice does not contain a biocide, I can tell you that. It's merely a cetane improver and has some lubricity additives that ULSD lacks. Any 'snake oil' additive that don't come with the required MSDS labelling don't. Why I use Powerservice Bio-Kleen. It comes with the required MSDS labelling attached to the bottle and it's not cheap either. Far as where I 'got it', I suspect it was the B20 I was using at the time from the station up town. I quit using B20 after that incident and I've never had an issue since. I buy my ULSD off road (not B20) at the same station and they do sell volume, all the farmers around here use them for fuel as they deliver too. I'm done with the 'green' stuff, remediation was very expensive.
Smells like french fries and destroys your injection system. Not for me. In fact (though I didn't knw it at the time), Kubota discourages the use of B20 in their tractors, never did however, just the truck and that was plenty enough. In fact, not sure if they even offer B20 anymore.
I believe my big mistake was I topped off the truck and parked it for the winter and come spring it was loaded up with the stuff. Had to drop the fuel tank, dispose of the fuel, new tank pickup and sending unit, new lift pump, new fuel bowl, new fuel lines, numerous filters and a lot of labor and grief. Just lucky it didn't get past the filters and into the injectors. I've heard it destroys them.
/ Algae & Microbal growth in diesel #15
I treated 230gal with the PS "clear diesel" in 2020. No issues so far but I'm going to get the bio clean and treat the tank. The SDS on the "clear diesel" only shows "trade secrets" so that's not great.
/ Algae & Microbal growth in diesel #16
Good idea. Biobore also markets a biocide. Same deal, attached MSDS warning label. Trade secrets mean nothing. It has to list the ingredients and the cautions for use. Not familiar with 'Clear Diesel' Sounds like phooey to me.
/ Algae & Microbal growth in diesel #17
The issue as posted above is, you can kill the microbial algae but the 'dead bodies remain' and you have to remove them one way or another as the corpses are what clogs the filters and if they get past the filters, will destroy the injection pump and injectors. At leas when you terminate them they aren't reproducing and making more.
/ Algae & Microbal growth in diesel #18
If you treat when the fuel is new does this become an issue?
/ Algae & Microbal growth in diesel #19
It depends where you store your fuel between the seller and your tractor. Put clean, clear fuel in any contaminated tank and you could have problems.
I avoid big farm storage tanks and have truck mounted tanks for quick in/out storage. I keep those tanks treated, clean and screw on new filters often.
I run a lot of different farms, so I fuel “on the go“ from 80 gallon truck tank. The downside is I have to run for fuel 2 even 3 times a week during heavy farming, but the fuel depot is close so not a big deal.
Having 80 gallons on hand will usually get us through one day of intense farming, but I sleep better knowing its gone quickly and not laying around in a tank.
If you have a truck, I highly suggest a truck mounted tank. You bring your fuel to the tractor rather than the tractor to the fuel. It’s easier and you can go anywhere.
/ Algae & Microbal growth in diesel #20
How long are your 5 gal jugs sitting? If you empty/refill them regularly & burn the fuel through your engine, keep the tractor tank topped off when it sits, are using good clean fuel from a high volume (turnover) source, & don't go through a lot of dewpoint cycles, you should be fine. If the jugs or tank are sitting around for a long time, if they aren't sealed tight, if you have high humidity and temp fluctuation that cause condensation to happen in tractor tank or jugs, you could keep having problems. All depends on what you are doing.
