Air nailer question
   / Air nailer question #11
A round head nailer uses a round head nail. A clip head nail gun uses a clip head nailer. The clip head is kinda like a half moon of metal for the nail head instead of a full circle. A round head is what you would get to use with a hammer. Clip heads allow more nails to be packaged togather.
Can't help on the angle to get.
To make it more confusing, some nail guns can work with metal connectors and some can't. Don't know if that is a concern or not.
I have been resisting buying a nailer for years because of the cost and I would only need it from time to time. And I kept trying to by One Perfect Nail Gun. Which I finally figured out does not exist. :D
I do have to build some things this summer and I think a nail gun will finally get bought.....
Later,
Dan
   / Air nailer question #12
Tdog said:
Thanks for the replies. Now I'm ready to really show my ignorance. What is the difference between 'round head' & other nailers? And what are the different angles 21 degrees, etc. What should I be looking for?
Duh!
Jack
Round head it just that, the nail has a normal round head. The other is called a clipped head nail. The nail head is sort of D shaped, they can get more nails on a strip. Some areas the code doesn't allow for a clipped head. I used to work for Senco and there were many tests done and the debate still goes on as to which one is better. Senco would coat their nails with glue to set them in the wood, so the clipped head would uaually pull through the wood. Duofast had a round head and no glue but when tested the nail would pull from the wood. Seems to me like a failure is going to happen either way. The Framers likes the clipped heads because they did not have to reload as much. I love to tell how Senco came out with a 15 or 16ga 3.5" framing staple. Glued staples have proven to hold better than nails (remember staple legs were designed to separate or bend in the wood), and even with the cheaper price of the staples it didn't sell.
If you are just going to use it for a shed, the HF stuff ain't that bad and is a lot cheaper.
As far as the belt hooks, At Senco we had a company make up bent piece of aluminum and it was held on at the air coupler. It would be easy to make one up. Years back I found a guy on Ebay selling these and I bought all 5 for $20 or so.
Good Luck,
Rob
   / Air nailer question #13
round head, no question.
You need a special nailer for simpson strapping and the like. I've got it, I love it, you know if you need it - otherwise you don't
   / Air nailer question #14
There are 'round head' and 'clipped head' nailers. "Round head" means the head of the nails have a full, round head, just like a regular common nail. "Clipped Head" nails have half the head removed so they fit in the gun. Some building codes do not allow the use of clipped head nails because of reduced holding power. To address this, some nailers can use nails where the shaft is not in the center of the head, but there's still a full round head.
The different angles can help if you are nailing in tight spots and/or hold more nails.
There's a lot of information on this topic out on the web.
I use Paslode Cordless nailers, no need to deal with an air compressor and hoses.
   / Air nailer question #15
Northern Tool vs. Harbor Freight vs. name brand....
I "made do" with a HF framing nailer for several years, and it had a really bad habit of double firing. It was the older model with the clipped nail design. Also, my air compressor would go down to 80psi before it kicked in, and the HF nailer would leave the nails sticking out slightly, so I'd have to go back and nail them the rest of the way in.
The last straw was the double firing. I was up on a ladder putting up a 16' long 2x6 (fascia board). Did the double nailing thing, but the second nail just went into the very edge of the board and then straight on through. My hand was 6" behind, well out of the way, so I thought. Broke through my glove, into the skin a little way. Not bad enough to require a doctor visit, but I did quit work for the day. Bought a new Porter Cable the same day. It has a single fire mode that I always use. Bonus is that nails are easier to find for it, and they always go in all of the way. I caught a sale and got the PC for $179. You can pick it up for $189 from Amazon. Amazon.com: Porter-Cable FR350A Round Head 2-Inch to 3-1/2-Inch Framing Nailer: Home Improvement
After using the PC nailer for a while, I realized that the spring on the foot of the HF nailer had too much "spring" to it, meaning that you had to really push down on the HF nailer before you could pull the trigger. I took the spring out and cut it down a little so that it was closer to the amount of pressure required of the PC nailer. After I made this modification to the HF nailer, I no longer had problems with double nailing.
However, the PC nailer was just all around a better gun: depth adjustment, single fire mode, set the nails all the way, easier to find nails, and you could find truly galvanized nails for it. (HF has nails they call galvanized, but they aren't).
Now I keep the HF nailer around for people who want to borrow my framing nailer....
After using the Porter Cable
   / Air nailer question #16
I have a HF nailer for myself along with several of their trim/staple/brad guns. For what you pay ($39 on sale) its a great gun. When I had my house built I specified I wanted all ring shanks in the entire house. Having quite a few of those Paslode sticks leftover I have found that they fit/fire perfectly in my HF gun. I bought the nails at Lowes.
   / Air nailer question #17
Buy a 30 degree Paslode cordless and be done with it. Your not dragging hoses around and waiting for compressor. Nails are cheap in comparison and gas refills are cheap as well.
Brad
   / Air nailer question #18
Brad
thats what i just pick up :)
   / Air nailer question #19
If you get the light 1/4 inch pex hoses they aren't an issue - I'm usually towing a 100 foot hose and it doesn't bother me. The air thing is odd - the average contractor compressor can run 2 framing guns going nonstop.
I've played with the paslodes, have to confess I didn't like them much.
If you go to just about any job site around here, you will only see one framing gun - the hitachi. At $300 plus I'm not saying everyone should get one, but if you are doing any real framing its the gun to have. Cost is only a couple of boxes of nails in any case at this point...
   / Air nailer question #20
I have a framing gun made by Duo-Fast that I bought back in 1992. Other than replacing some O-rings, it has been a good tool save for the weight which if memory serves is up around 16lbs!
I bought it for personal use which has included apartments, houses and farm duty. I would not be without an air framing gun.
I had a contractor doing some work on my barn and he came with a couple of new Paslodes. I got to try them out a bit. Nice to not have to drag around an air hose but for production, I would think they would be too slow. Nor did I care for that gas smell.
They seemed touchy as well though the guys wielding them could probably use training. Like any tool, if it is your own, you tend to invest some time into understanding the tool and maintaining it.
Clipped heads? Penny wise, pound foolish.
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A51691)
1996 JLG Commander...
UNUSED LANDHONOR LHR-G209 ANCHOR SHACKLES (A54757)
UNUSED LANDHONOR...
2007 Saturn Sky Convertible Coupe (A55853)
2007 Saturn Sky...
New Holland 325 Manure Spreader (A55218)
New Holland 325...
92" ARTICULATING 4 WAY SNOW PUSHER BLADE (A54756)
92" ARTICULATING 4...
2019 INTERNATIONAL RH613 SINGLE AXLE DAY CAB (A54607)
2019 INTERNATIONAL...
