Air hose
/ Air hose #1
jcummins
Creal Springs, IL
Kubota M7040, F3680, Mule Pro Fxt
I use a small pancake air compressor at the end of my workbench for various air issues. I have one of those yellow coiled hoses....works well for my purpose there....but it's the only place I use this type of hose.
Well the hose broke right at the end of the bard fitting. So I cut off square, and try as I might...I can't get it back on. Tried silicone spray on the bard....heated the hose trying to expand it...just won't go on.
How do you get this type hose back on? OR...is there a better solution. Don't want regular air hose like I use on my larger compressor...something small.
Here's what I'm working with.
/ Air hose #2
I've used a little heat and a pair of needle nose pliers to expand the hose just enough...
/ Air hose #3
Use a heat gun, not a torch to heat the tubing. A torch heats it too fast and will melt the hose. I have reinstalled coiled hoses back on the barbed fitting with this method. HF sells heat guns cheap if you don't have one.
/ Air hose #4
1st try boiling water. ... Next, heated cooking oil.
/ Air hose #5
A 25' x 1/4" coiled air hose at HF is $6.00, a heat gun is $15.00 according to their website. I know what I would do.....
/ Air hose #6
I recently had the same problem with 1/2" soaker hoses and used hot water and needle nose pliers.
/ Air hose #8
I use fuel injection rated fuel line hose. ;-) small light and flexible
I HATE that curly stiff plastic stuff........
/ Air hose
I hate the curly hose too...but at $6+ a foot for that hose...can't do that.
I would love a reasonable price alternative though.
/ Air hose #10
I had that yellow curly hose on my compressor for a while. It kinked, twisted the wrong way etc. Got rid of it and went with just straight rubber hose.
Otherwise, I've used a heat gun or boiling water and a pair of leather gloves to fix this type situation.
UNUSED FUTURE D680 HYD PILE HAMMER (A65055)
UNUSED FUTURE D680...
UNUSED JCT 60" CLASS8-8000 LB CAP PALLET FORKS (A65055)
UNUSED JCT 60"...
2022 EZ-GO ELITE...
2015 Audi A4 AWD Sedan (A61574)
2015 Audi A4 AWD...
2015 Chevrolet Tahoe SUV (A64557)
2015 Chevrolet...
2014 Takeuchi TB260 Midi Excavator (A64553)
2014 Takeuchi...
