Air Handler in a Ranch
/ Air Handler in a Ranch #1
WVH1977
Platinum Member
Richmond, VA
Massey 2860M Cab, Massey 1E.35, Gravely Pro-Turn 560, 1989 Ford D47 Dump Truck John Deere LX178
Hello All,
I am almost finished with my ranch style house plans and my builder asked where I want the air handler (in the attic or under the house?). I am not sure what the best place would be. I know in the ceiling I would not have to worry about furniture on top of or little items falling into the vents. Would the system run more efficient under the house? He recommended the attic and another good friend recommended under the house. Does it really matter?
Thanks in advance for any and all responses.
/ Air Handler in a Ranch #2
ok... so it's a ranch in VA... but could you give a little more info...
Is it a full basement or crawlspace.
Is the space under the house sealed? or conditioned?
What type of insulation does the house have?
I would usually prefer to see the air handler & duct work in a conditioned space; that said my house has duct work in both conditioned & unconditioned space because it was retrofitted. (& it is for AC only). I would be interested to know why your builder is recommending the attic... (besides it is easier (cheaper) to run duct work (flexi-duct) through an attic space). But before making a final recommendation I would be more interested in those construction details... I'm kind of surprised this wasn't discussed during design phase of this build....
/ Air Handler in a Ranch #3
Gotta stay on top of the condensate drains on attic installed airhandlers. If not the algae or insulation will plug the drains and it could cost thousands to correct the water damage.
/ Air Handler in a Ranch #4
At my employer, I deal with lots of problems caused by air handling equipment condensation dripping/not draining in ceilings, damaging those ceilings and things below them. Based on that experience over the last couple years, I'd opt for anything with water in it to be the lowest as possible in a house.
/ Air Handler in a Ranch #5
1) Where do you want to go to change the filters
2) Is the attic insulated or would the air handler and duct work be exposed to the very hot air in an attic.
3) Condensation in an attic drip pan can be an issue.
4) Many attic units are done almost completely in flex duct which is not well insulated and needs considerable supporting which is usually not done well.
/ Air Handler in a Ranch #6
Cold climate- keep it low. Hot climate- put it in the attic. Those are just guidelines though- you won’t go wrong with either if they are installed correctly. But from an efficiency standpoint those guidelines will serve you well.
/ Air Handler in a Ranch #7
Neither is a good place from a service standpoint. Can't they find a corner to wall off on the main floor. You only nee a 30" X 30" space and sometimes less with today's compact units. When I was a service tech non-favorite places in ascending order are: Crawl spaces, attics, closets, basements. Like has been mentioned cooling condensate drains are problems waiting to happen, add to that the condensate drains for condensing furnaces and water heaters which are also highly acidic.
Up here garages are a favorite place to put them also, that is where my furnace/air handler is.
Ron
/ Air Handler in a Ranch #8
I just visited a friend with a large ranch style home. His propane furnace and air conditioning units were out in his garage. Easy access - no problems if condensate should "break loose" - no noise in the house when the units are running. His only other choice would have been in the basement. The house has exposed beam ceilings.
/ Air Handler in a Ranch #9
I've got a sprawling ranch with geothermal heat pump. I put the unit in the 5 foot crawlspace to avoid water issues and so I wouldn't have to climb ladders to inspect or change the filter. Has worked perfectly. It's quiet, super efficient and easy to access. If I did it over again I'd go with a full basement and put it there. I did put in special intakes in certain rooms - high in a room hit a lot by winter sun, and another where I have a woodstove. Works well to circulate heat in the winter.
/ Air Handler in a Ranch #10
We don't have basements here in East Texas, so the two options are in the attic or in the house/garage. Seems like most new installs are going into the attic. I don't like this because it makes it very hard to maintain it. Seems like a lot of people don't realize that you need to add a little bleach to the drain line very month when you change your filter or the primary drain line will start to grow algae inside of the pipe and quickly plug it up. Then the water will fill up the pan and drain from the pan if there isn't any insulation or debris in the pan. A lot of the time that secondary drain is plugged and the water overflows the pan, causing damage to the ceiling. I get a lot of jobs repairing that damage!!!
Other issues with having it in the attic are having a path to get to it that does not disturb your insulation. I've built wood deck type pathways for clients to get to their units in their attic that is above the insulation. Most people have a path to get to their units in the attic that are completely devoid of insulation. Kind of like having a window in your ceiling. I have elderly clients that pay me to change their filter and pour bleach down the drain for them, but they tend to put it off to a couple times a year when they want me to do other things for them too. Sometimes the filter is at the return in the house, so nobody ever goes into the attic to add bleach, and nobody ever looks at it to see if their is a drainage issue.
In some higher end homes, they put the unit in an upstairs room that is built for this purpose that is easy to get to through a regular exterior type door that seals out the attic heat to some degree and it's all installed on a platform high enough above the joists to allow plenty of insulation. In those homes, there might be 3 units in that area, but usually two. One for upstairs, one for downstairs. If it's going to be in the attic, this seems to be the best way to do it.
I prefer to have it on the main living level of the house. When I built my parents house, I put it in their garage, kind off off to the side of where they park so it's never in the way of anything. The water heater is next to it and sits on the same wood platform. Filters and bleach are sitting on the platform too for easy access and a reminder to change the filter every month.
In my house, I have it in a small 8x6 room behind my garage that you have to go around the side of my house to get to it. There is a small porch over that exterior door, and lights with an outlet inside that room. My electrical pane, my water heater and my AC unit are all in that space, along with extra filters, bleach and drain hose in case I have to replace my water heater. This is also where my access to my attic is located.
My clients with their units on the living level of their homes have it in the hallway, or in their garage. Both areas are easy to get to, which is very important for the life of your unit. The filters have to be changed regularly, and the coils should be washed every year, two years max. I personally change my filters twice a month, but I have 4 large dogs and doggy doors that allow them to come and go when they want. Dust is a constant part of my life.
/ Air Handler in a Ranch #11
Mine is in hallway mechanical closet (5x5), along with water heaters, softener and room for Terry's cleaning supplies. Ductwork is in the attic. All the metal plenum and duct is spray foam insulated as well as covered by blow in insulation.
I wanted easy service access.
2015 PETERBILT 320 6X4 T/A GARBAGE TRUCK (A66091)
2015 PETERBILT 320...
Hitachi EX 270 LC, Cab, 32" Track Pads, Grapple (A62679)
Hitachi EX 270 LC...
2020 INTERNATIONAL MV607 REEFER (A67714)
2020 INTERNATIONAL...
2023 CRUISER RV SHADOW CRUISER (A67714)
2023 CRUISER RV...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
2014 Jeep Grand Cherokee SUV (A66738)
2014 Jeep Grand...
