Air Compressor Questions
/ Air Compressor Questions #11
I agree.. I don't like those oil less compressors. This little pancake job I have is 4gallon 2hp.. I think I had it backwards when I posted earlier.
I think the guy that had the tank explode might have had a cutout fail or something...
In the shop at work, we had an older 60gal compressor fail ( 5hp motor died).. Found it was 40$ more expensive to get a new campbel hausfield 60 gallon compressor, than to buy a new 5hp motor... we decided to get the new one.
In the meantime, we stripped the old compressor of the other 60gallon tank, and plumbed them together. Now the compressor runs a bit more in the morning . but then runs less during the day. Really powers our big 1" air gun nicely...
Unit is 2 cyl oiled.. pumps up to 135psi.. does it quick too.
We installed valving to seperate the tanks. etc.. has oiler/dewaterer, etc.
And they were going to junk that old compressor...( I was actually hoping they would... as the compressor worked nice... I was going to get some belting and either rig a pto setup for it, or use a belt pulley off my jd or cub to run it for shop air at my house... oh well...)
Soundguy
/ Air Compressor Questions #12
The cut out mayhave failed as the compressor was running when it happend.
How ever in this case there was no question that the tank had rusted to the point of failue. Once the tank started to split the rest failed. When examining the damage to the air reciver the areas areound the failure were well on the way to rusting through. Do not forget that condensation can lead to a fair amount of water pooling in the tank, which are not painted or protected from rust.
I also am a fan of oil type compressors as I like to be able to maintain my tools.
A good compressor, while more expensive at first will last longer, can be rebuilt and should cost less in the long run. It is possible to fine oil type compressors in all sizes.
Now, if I could just get a rotory vain or twin screw compressor in my shop! /forums/images/graemlins/grin.gif
/ Air Compressor Questions #13
I don’t think at lot of people respect the amount of stored energy in a compressed air tank. It is basically a bomb sitting there and of course the bigger the tank and the higher the pressure the greater the potential danger.
Any new factory-built air compressor should never rupture from the cutout switch failing if the tank is in good shape (not rusted, etc.) because they all are equipped with a safety pressure relief valve. They are sized for a flow rate that exceeds the capacity of the compressor. If the cutout switch fails to open the safety should lift venting air from the tank faster than the compressor can pump it in, preventing any serious overpressure of the tank. With lawsuits what they are today, could you imagine any manufacture selling a compressor not properly equipped with a safety valve?
Many manufactures recommend testing this valve periodically by pulling on the small ring attached to the safety. Be aware this will be a noisy experience and the safety may leak after testing, requiring it to be replaced in order to stop the air leak. This would be preferable to having a bomb go off in your shop or garage though. /forums/images/graemlins/smile.gif
/ Air Compressor Questions #14
I did just what you suggested, I had a 4 gallon, 2 hp compressor for nailing. When I got tired of wrenching, I picked up an 11 gallon portable tank and a 1/2" impact wrench. It will usually, but not always, remove one bolt from the tractor wheels before the wrench stalls out from lack of pressure. I'm in no real hurry, but I'd sure like a 5 hp 20 gallon rig.
/ Air Compressor Questions #15
Hey Soundguy (or anyone...)
While we're on the subject, I have an Ingersoll Rand T30 60Gal in my pump house that is nice but I seem to always need the air when I'm nowhere near the compressor! I would need, for example, at least 300 feet of hose to do the roof on our new run-in shed. A fellow I know offered me a nice chunk of change for it (he knows I rarely use it) it's in new condition. I was considering replacing it with a portable from Quincy Compressor for the same money:
Four cylinder single stage cast comp. with "splash lubrication"
8HP Honda gas engine, 3/8" Norgren Regulator
17 Gal ASME tank, 18CFM @100PSI, 16.9CFM @125PSI
Wheelbarrow style w/two decent wheels
I'll be using Drills, Nailgun, Air Blower, Sprayer, Wrench & Hammer
(one at a time mostly). The guy at the shop thinks it may be available with a bigger (30?) tank, but wasn't sure.
i would hate to sell myself short, but the portability is nice IF the unit will cut the mustard. I don't know if this helps 9-Mile, but it sure looks like a nice unit.
Any comments?
Here's their web page, 9-Mile!
/ Air Compressor Questions #16
Now, that's a truly portable compressor. Those numbers will run most anything you can throw at it. What do they want $$ wise? I have the Home Depot special $399 Campbell Hausfeld, twin cylinder, single stage, 60gal. vertical, 6hp electric, cast iron sleeved cylinders I am happy I bought it, it is 8 years old and is has not failed me. I run a 1/2 impact, 5" grinder, straight die grinder, 90 degree die grinder, 3/8 ratchet, 1/2 drill and a stapler with it. I will have to wait for air if my impact is working hard, or running that 5" grinder. It produces 9.3 cfm @ 90 psi. I have replaced the oil 3 times in the 8 years and I drain the tank atleast every third month. I expect it to last another 8 years. I debated the same brand and better brand dual stage compressors for some time before I bought, but could not justify the cost for my use. It is not portable, I now have 235ft of hose( 4, 50ft, 1, 25ft, and 1, 10ft) and will buy or borrow more hose if the latest project requires it.
there is nothing lost in running a long air line on your place. As far as tractor tires go, an $29.95 , 12volt compressor will solve that if you are stuck out back with a flat, or a portable air tank will work also. Bottom line buy the largest compressor you can justitfy (cfm rating @ 90 psi) thats what air tools run at.
The same compressor I have can still be had at TSC or lowes on sale for $439 and it will last with proper care.
Now if my needs required a portable that gas powered unit discribed sounds pretty good, but no 2,3,4,5, hp pancake compressor fits my requirements. happy compressor hunting
/ Air Compressor Questions #17
air compresser 101
This is the best dicussion re air compressors I've seen. It cuts through the hype. I brought an oiless 12 gal de Villbes which also makes the Sears units. It's loud and generally too small for air tools. It's only virtue is it portability and initial price. I try to buy the right thing the first time. This is a perfect example of flunking that goal unless you have very limited plans. /forums/images/graemlins/crazy.gif
/ Air Compressor Questions #18
</font><font color="blue" class="small">( Any new factory-built air compressor should never rupture from the cutout switch failing if the tank is in good shape (not rusted, etc.) because they all are equipped with a safety pressure relief valve. They are sized for )</font>
I was thinking more along the lines of an old compressor 'out in the barn'.. the thing is old and dirty/coroded.. cutout fails.. and so does pop-off valve.. due to age/dirt/muddaubers.. etc.
Just guessing... though obviously as we saw was metal fatigue / cosrrosion in the tank.
Soundguy
/ Air Compressor Questions #19
Don't buy an oiless direct-drive if is going to live in the shop with you! I want to shoot mine! I have a Cambell Hausfield "5hp" upright
It can do everything I want except sand blast and paint. The die grinder does make it wheeze though.
When looking at units, take the amps the motor is rated at, multiply by the volts then divide by 746 to get the "ideal" hp the unit can develop. The actual will be about 10% less. My "5hp" unit is actually like 2 hp which explains it being so weak!
/ Air Compressor Questions #20
</font><font color="blue" class="small">( I brought an oiless 12 gal de Villbes which also makes the Sears units. It's loud and generally too small for air tools. It's only virtue is it portability and initial price. )</font>
Well . . . , it does have one other virtue; I can completely rebuild one of them in less than an hour. /forums/images/graemlins/wink.gif /forums/images/graemlins/laugh.gif
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
CAT B30 HYDRAULIC HAMMER (A60736)
CAT B30 HYDRAULIC...
2016 FORD TRANSIT T250 CARGO VAN (A59575)
2016 FORD TRANSIT...
ATTENTION PLEASE READ (A60463)
ATTENTION PLEASE...
1770 (A58375)
1770 (A58375)
2015 Nissan Altima Sedan (A59231)
2015 Nissan Altima...
