Air compressor lines for stationary air compressor.
   / Air compressor lines for stationary air compressor. #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I used to have air lines run in my shop because I painted and needed the moisture removed. At the compressor I had a flex line to a vertical line that crossed over and dropped down to my moisture filter for painting. It looked something like this
It worked great but I just finished insulating my barn and had to take the lines down. I don't paint as much and don't want to run lines again. I have a two stage 100 gallon 180? psi compressor.
Can I just run a short rubber hose off the tank to a moisture filter, possibly right on the tank, and then run my air hose off of that? This would keep it easy for me and I only paint again equipment no that isn't very fussy. I mostly pump up tires.
I'd like to keep it simple. What do others do and how do you run your lines off the compressor to remove moisture?
   / Air compressor lines for stationary air compressor. #2
There are different types of "moisture filters", but what most have is a separator. This is essentially a fine mesh screen that collects condensing moisture droplets from the air as it passes thru, and drips them into a bowl.
To work, these require that the air coming out of the compressor has cooled enough for the water suspended in the air to condense when it hits the mesh. Those mounting it directly to the compressor usually end up with water in their lines, because the compressor tank gets hot and thus the air passing thru the separator is too hot to allow for condensation.
Even just 10 feet of copper or iron line running to the separator, connected to the compressor with a short length of flexible hose, would work much better than having the separator mounted directly to the compressor tank outlet.
   / Air compressor lines for stationary air compressor. #3
My shop has a 7 1/2 hp Cambell Hossfeld compressor. Over the past ten years, my requirements for compressed air has dwindled to be much like you describe. I find that the TANK takes care of the lions share of the water removal. I don't run any water filter at all. When I do have the need, I set the filter /separator near the point of use. Everything run by rubber hose and quick disconnects.
This is in the North East, I might reconsider if in Florida. If in AZ, even the water trap might be un needed.
   / Air compressor lines for stationary air compressor. #4
It all depends on duty cycle. If you only ever use a small volume of air at a time, this can work fine. But the first time you do a job that keeps the compressor running long enough for the tank to heat up, this method stops working.
Side note on draining tanks: I probably have the same compressor as you, a 7-1/2 HP x 70 gallon "Extreme Duty" from CH, purchased probably late 1990's or ca.2000. Other than a few blown motor capacitors over the years, it's been a great little workhorse, but draining the tank was always a PITA. More importantly, since I'd use it hard on weekends and mostly let it sit during the week, the thing was always left cooling and condensing unattended. So, there was basically always a quart or half gallon of water left in the tank all week... for 20 years.
I had looked at the "old school" auto drains years ago, operated by the unloader valve puffing against an air-operated solenoid, and the whole rig seemed impractical to rig on that compressor type. But then a year or two ago, someone here (I think @5030 ?) mentioned these little timer relay operated solenoid valves that you can plumb in as an auto drain, and I picked one up cheap on ebay or Amazon. Now the thing does a 5 second piss every hour, or thereabouts, which is more than enough to keep the tank always dry, given my usage and air-conditioned shop environment.
The timer is adjustable in both frequency and duration of drain cycles, and I'd recommend this to anyone with a stationary compressor. We've all seen tanks rusted thru from the bottom, and the amount of stored energy in a 70 gallon bottle at 140 psi is absolutely devastating, should one ever rupture.
   / Air compressor lines for stationary air compressor. #5
Got a link for one of these drains?
   / Air compressor lines for stationary air compressor. #6
I run my 60 gallon Devlbiss (?) From outside the wall with rubber joined to the internal infrastructure. The inside I have four "U"s that are about 5' long with a petcock at the bottom of each. Catches most water before it goes the the multiple drops. Each drop has a reg/air or oil regulator to hook to. Works well for me but I did it with the forbidden PVC. Haven't had a problem at this house yet. When it does I will go to copper or black pipe.
   / Air compressor lines for stationary air compressor. #7
Compressors Direct (use your search engine to look them up). They not only sell new compressors but replacement parts and filters as well but more importantly, sell the Suburban Manufacturing timed auto drains (I have 2 of them, one each on each compressor).
They sell both the Tsunami condensate drain which works via pressure differential as well as the timed unit (that I use). They are on Amascon as well but the ones on Amascon are Chinese. The ones on their website (Compressors Direct) are American made which I prefer.
   / Air compressor lines for stationary air compressor. #9
I'm in a similar situation. I took down my hard lines and water filters when I sold my Illinois home, and brought the compressor and all the piping, etc with my to Iowa. After I built my shop (finished early last year), the compressor is in but I still have the piping sitting here in a corner - waiting. Haven't got that part of the shop build yet. Decision time...
   / Air compressor lines for stationary air compressor. #10
I moved in 2011, and found myself in the same situation. I finished building the new shop in 2015, operating out of an unfinished barn for the 4 years in-between, but it took me until 2023 to find time between other projects to actually put up new hard line.
I made do by putting about 10 feet of 1/2" copper line on input to separator, and then connecting that to compressor with another 100 feet of 1/2" hose. Direct 1/2" NPT connections, no quick-disconnects, to minimize the pressure drop of an already-bad system. It wasn't great, but thanks to my compressor residing in an air-conditioned shop, I got by.
Now it's all hard-plumbed in copper, 3/4" line into three long parallel runs in 1/2" copper, before collecting back into a single 3/4" feed into the separators on each floor. All painted flat black, it works very nicely as a radiator, ensuring air going into the separator is as cool as possible, for maximum moisture extraction. Auto drain on compressor, my only possible point of failure is if I forget to drain the separators.
Usually doing in-home repair work on copper, where there's always that last bit of water in your line ruining a solder joint, it was so nice to work on clean, new, and dry copper line for a change. Probably 100+ solder joints, and not a single leaker among them. All done in K & L type, avoid the type M if using copper for air pressure.
2001 Ford F150 (A50121)
2001 Ford F150...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
1998 C6500 Chevy, 3126 Cat Engine (A52384)
1998 C6500 Chevy...
2022 Adams CLC-1013 Conveyor - New (A52748)
2022 Adams...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
