Air compressor from PTO... need CFM for sand blasting
   / Air compressor from PTO... need CFM for sand blasting #11
First thing, look on google for an air usage chart.
All the sandblasting outfits have them, Empire comes to mind.
Then work from that chart to figure out what compressor size you need.
I built one that ran off the PTO like pictured above, I get 200 CFM.
I then purchased a work truck with a engine drive one on the back, it is
a grimmer Schmidt 1/2 engine affair, put's out 150 cfm, and runs great
Who would think a ford 302 v-8 could run so smoothly on 4 cylinders ?
   / Air compressor from PTO... need CFM for sand blasting #12
"Who would think a ford 302 v-8 could run so smoothly on 4 cylinders ?"
As long as it's the RIGHT 4 cylinders - might "lope" a bit if you were to make one that used all 4 firing cylinders in order, then all 4 compressor cylinders :D
My local tire guys have their ag/industrial trucks fitted with those small-block Ford compressors - when they came out and replaced all the tires on my 580B I found out how LOUD they are, but they sure make my 5 horse 23cfm look like a wimp... Steve
   / Air compressor from PTO... need CFM for sand blasting #13
The CFM required is in direct relation to the media and orifice size and pressure used. If you have a small orifice and fine media 9 CFM MAY work.
Now to the second part of the question. The easiest way to deal with the constant pressure build-up is to dump it with a pressure sensitive valve. That way the pump and tractor can just keep going. The second idea would be an electric clutch between the PTO and pump (like the AC on you car or truck). I'm guessing the clutch solution would be more expensive.
   / Air compressor from PTO... need CFM for sand blasting #14
Bukitcase,
Odd that they were so loud.
Mine has a normal muffler, and it kind of just hums along nicely.
   / Air compressor from PTO... need CFM for sand blasting #15
Doug, when I think back it seems like theirs was only loud when the compressor half kicked in - maybe it didn't have a breather on the compressor inlet?
Dunno, too long ago and at the time I'd just got my 580B and was more concerned with gettin' enough traction to do the push-out below my shop ('bout 800-900 yds of material moved with 3ph and Gannon box on the back)... Steve
   / Air compressor from PTO... need CFM for sand blasting #16
Steve.
Maybe the tire tech ran it at full throttle because he thought you might be hard of hearing.
   / Air compressor from PTO... need CFM for sand blasting #17
Eh?? Whazzat? Speak up, you young punk... :D
2012 Mitsubishi Fuso FEC52S Cab and Chassis Truck, VIN # JL6AMG1A0CK003828 (A57453)
2012 Mitsubishi...
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58214)
1999 WEST WIND...
Grove 4x4 Rough Terrain Hydraulic Crane (A55851)
Grove 4x4 Rough...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
2021 Deere 331G (A53317)
2021 Deere 331G...
