Tires AG tires on backwards
/ AG tires on backwards
My Bad.
Sorry everyone. Today I double checked thinking the V pointed backwards but I was wrong on all tires. The V is pointing forward as they should. I guess the snow print is what threw me.
Next time I'll double check before putting foot in mouth. :(
/ AG tires on backwards #22
My Bad.
I'm good a putting both my feet in my mouth. Don't worry about it.
/ AG tires on backwards #24
My Bad.
Better to ask and be sure, than to always wonder!:) The only bad question is the one not asked.:D
/ AG tires on backwards #25
Administrator, please delete this threasd.
/ AG tires on backwards #26
My AG tires seemed to be on backwards. The thread is like this V instead of ^ pointing in the direction you are driving forward.
Will this harm anything ? Should I reverse the tread by just reversing the wheels?
Hmmmmmm.....so the first post says that he believes the tires are mounted backwards. Anyone and everyone who has been around Ag tractors knows that the V must point forward. Now if you will read the first post again you will see that he clearly states he believes the V is pointing backwards....
Default Re: AG tires on backwards
Quote:
Originally Posted by WarrenF View Post
WHAT???? Read the first post again. The tires are on backwards, and the easiest way to fix that is simply swap the tires....left to right and right to left.
::snicker:: "Sow's ear" ::snicker::
Would you now like to revise and and change your remarks?
/ AG tires on backwards #27
larry
/ AG tires on backwards #28
Read post #2 and #3 and think about it.
/ AG tires on backwards #29
WarrenF
The V does point backwards in the track in the snow.
You must be looking/thinking at/about the top surface of the tire.
Maybe this thread (thanks for the one pic) will help other readers who might be confused, as it really does sometimes take a while to sink in. :)
I recall as a small boy walking the rural roads and farm lanes on my Uncle's farm, and seeing the bar marks in the gravel/sandy road. The bars were telling me which way Uncle Tom's tractor was headed, and that was important information to me as to where I might find him and his tractor.
Spyderlk
I do like the gif :D
/ AG tires on backwards #32
Back on the farm. Here we go again. Every once in awhile it would be necessary to reverse the wheels to get a wider stance for certain row crops. This was after the wheels had been rotated out on the rim. By reversing and rotating the wheels out you could gain about 18" depending on the tractor.
/ AG tires on backwards #33
Wouldn't changing side for side keep the lugs "pointed" in the right direction so they are not on backwards? Maybe that is what you meant by "reversing". :)
/ AG tires on backwards #34
Changing from side to side is rotating. (You are rotating from left side to right side.)
Flipping them inside to outside is reversing. (Youare reversing their rolling direction.)
If you do either one they will be on backwards. (Backwards to the original direction.)
If you do both, rotate and reverse, they will be turning the same direction as original.
As has been mentioned... Your tracks in the snow or earth, on a (driven wheel) should always point to where you came from.
On a pushed wheel like the front tires of a motor grader, they should show a track pointing to where you are going. KennyV.
/ AG tires on backwards #35
What is funny around here sometimes the motor graders have the rear wheels on backwards so they can get themselves out of the mess they got into. They are usually alone when grading the logging roads and cell phones do not help where they are.
David Kb7uns
/ AG tires on backwards #36
David Kb7uns
I've seen experienced grader operators get themselves out of some fairly deep ruts with the hydraulics on the blade. Using the blade like a paddle to push themselves backwards.
Lately I am seeing more and more road graders with what looks like giant turf tires, equally good in both directions and probably a little better lateral traction too.
/ AG tires on backwards #37
My neighbor reverses his front tires in the winter to get better traction when blowing snow.
Makes sense when you think about it.
/ AG tires on backwards #38
My Bad.
All kidding aside...any ag tire I've seen in the past 20 years has a "direction of travel" arrow inprinted on the side wall. Anyone???
/ AG tires on backwards #39
Yep , should have direction arrow on side of tire . :eek:
/ AG tires on backwards #40
Mine do. I noticed it yesterday when I was looking for the tire size so that I can record it here at home.
