Aerating
   / Aerating #21
No rentals in this area that I have come across. That would be a huge benefit.
   / Aerating
We have a couple different companies that rent spreaders & aerators.
Have you tried local dealers who sell them?
   / Aerating
On an old hayfield what do you notice different the next year? Better drainage, yield, or both assuming aerating is the only thing you did to the field
I would say the thing it does the most is cut root-bound clumps apart and allows clump grasses to spread. Also more water gets down to roots and improves drainage.
   / Aerating
I core aerate my 5 acres at least once, if not twice a year. Really helps with compaction, and getting nutrients down to the roots of the grass. Have a fair amount of clay, so compaction is a problem.
If I overseed with rye, then I have to mow it 2-3 times in winter. Not crazy about that, but to each his own.
Duffer, check your PM’s
I sent you a message
   / Aerating #25
Others, who graze their cows on my fields, have noticed no change from core aeration. My understanding - core everything once every 5 years, in the spring. Annually, core compacted areas - again, in the spring. But perception is the tie that binds. If no improvement can be seen, hard to justify the fuel and LABOR costs.
   / Aerating #26
please check me on this, but applying agri lime will improve the tithe of the top soil in a field as well as mechanical means to improve root aeration
   / Aerating #27
I would be going out beyond 100 miles. Local dealer a no go.
   / Aerating #28
I aerate my little 6 acre place. If I get it timed right in the spring with my granular fertilizer application, I get a good bang for the buck. The problem with a core aerator on my black clay soil is timing it when the soil moisture is just right. But the aerating does increase surface area and water penetration, so I get better utilization of the fertilizer.
   / Aerating
What works real nice on clay is
Plug aerate as deep as you can.
Dump a load of rich topsoil or mushroom soil in the field.
push the soil along the ground with a bucket or a chain drag into the holes.
   / Aerating #30
Research trials locally with our Cooperative Extension agent found that aerating did nothing. Our glacially impacted soils have glacial marine deposits the restrict root growth but they are generally a lot lower than any aerating can reach. Those who no-tilled deep tap root forages had better luck and the cost was easier to justify than the aeration. Like the idea of helping push the fertilizer down though.
20Ft. Bi-Parting Wrought Iron Gate (New/Unused) Galvanized + Powder Coated (A59225)
20Ft. Bi-Parting...
2015 Kia Sorento AWD SUV (A56859)
2015 Kia Sorento...
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A55853)
2003 International...
1611 (A57192)
1611 (A57192)
2019 Caterpillar 259D Compact Track Loader Skid Steer (A55973)
2019 Caterpillar...
2005 Chevrolet C4500 Altec Bucket Truck (A56858)
2005 Chevrolet...
