Aerating
/ Aerating #1
Hay Dude
Epic Contributor
The Last Red State in the Northeast
Challenger MT655E, Massey Ferguson 7495, Challenger MT555D, Challenger MT535B Krone 4x4 XC baler, 2-Kubota ZD1211’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mower, NH wheel rak
Been aerating some of my fields last few days.
Took a few photos.
/ Aerating #2
as a commercial operator do you honestly feel it makes a difference in the yield of the fields by the time you factor in fuel costs? or are you just doing it because customers are asking for it and you get paid so it is a win-win.
I have done my lawn a few times over the last 14 years and can't really say I noticed the difference but that was with no fertilizer applications. I always seem to think, atleast for northern climates, that the frost probably does more good than aerating but it certainly can't hurt.
/ Aerating #3
hook a drag on the back of that aerator and you wont even see the carrots left behind. (if the customer complains)
/ Aerating
I’m in the process of rehabbing about 40 acres for a customer. The aerating was done to try to reverse a lot of years of neglect from previous farming practices.
/ Aerating #6
I’ve always wanted to aerate our plac, but I went to a county extension workshop on compact and the said that it doesn’t really help it just works the top few inches of a pasture.
They said that planting annual plants works good. The roots penetrate they break up hard pan and when they die they allow water to penetrate as well as adding organic material to the soil.
l’ve been planting annual rye for this reason.
/ Aerating #7
I core aerate my 5 acres at least once, if not twice a year. Really helps with compaction, and getting nutrients down to the roots of the grass. Have a fair amount of clay, so compaction is a problem.
If I overseed with rye, then I have to mow it 2-3 times in winter. Not crazy about that, but to each his own.
/ Aerating #8
It’s winter forage for grazing and cuts down on hay purchases.
/ Aerating #10
Are you seeding now?
Best,
ed
/ Aerating
/ Aerating #14
If your question was to me.
In South Carolina we can seed rye any time after the third week of September.
Thanks, was actually asking Haydude, his climate is a little more like mine. Plenty of winters I would like my climate to be more like yours:)
Best,
ed
/ Aerating
I would aerate first, but that field was aerated and not seeded.
We no-till drilled other fields.
Sorry if I wasn’t clear.
/ Aerating #16
I think you are clear, I am just dense, do you have bermuda or some kind of spreading grass? In all my years we never did any work on brome or fescue without seeding.
Thanks,
ed
/ Aerating
Thanks,
ed
I have disled-in timothy and no-till drilled it as well. Also, orchard grass and endophyte-free fescue.
One of my favorite grasses is reeds canary grass for a strong, spreading grass on tough ground or wet ground.
/ Aerating #18
/ Aerating
Interesting. Is this the first year you have done aerating? I have been comparing Aerway and Ranch Works for possible future purchase. On long term hay I believe it would be good to break the surface just unsure how much value vs cost it really provides.
I have been doing it for about 10-12 years. The unit in the pic is a rental. It’s very cheap to rent. Never have felt the need to own one, but it was offered to me to buy.
/ Aerating #20
On an old hayfield what do you notice different the next year? Better drainage, yield, or both assuming aerating is the only thing you did to the field
2022 GMC Sierra 2500 HD 4x4 Crew Cab Pickup Truck (A64556)
2022 GMC Sierra...
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
2022 EZ-GO ELITE...
2019 PETERBILT PB337 LUBE TRUCK (A63276)
2019 PETERBILT...
Big John Semi Trailer (A65640)
Big John Semi...
PVC PIPE FITTINGS (A64276)
PVC PIPE FITTINGS...
