Advice would be appreciated
   / Advice would be appreciated #31
parts availability on older tractors: My experience is mainly w/ JDs on older iron. We have several. Our newest JD is a 4320 built in '67? I believe? We did have to wait on the overhaul kit for the motor but only a few days. Believe it or not, our local Greenline dealer has a lot of the parts for our 2 cylinder fleet (build dates from the 1940's up to our newest 830 built in '62) IN STOCK! But I believe this may just be leftovers from the days before "just in time delivery" when places actually had an inventory.
The more poplular farm tractors (4020, 5020, 4320, 4440, 4230) would still have a large parts availability.
And let me tell you, that 4320 we just overhauled is one SWEET tractor. And other than maintenance and barring any abuse, I don't expect me or my 5 year old son to have to do anything major w/ it.
Sheet metal - well, don't know that we have ever replaced anything larger than a side panel or two, but they are available from Greenline and some aftermarket places. Also, ou might find a nearby Ag Auction like Brinkley's in Oklahoma. Lots of stuff can be found on their "Salvage lines".
I am like one of the other posters on clearing the mesquite. Chemicals may be the way to go for long term control. But to make a quick showing, you will need to rip them out by the roots. I'll say it again, dozer and a root rake. Mesquite can be very hard on $500 rubber tires.
   / Advice would be appreciated #32
Hello Russ and welcome to the board!
I've been busy so I'm chiming in kinda late here. We are practically neighbors. I grew up in Victoria and drive past your place on Hwy 77. Also, I work in Austin so like I said above....
Anyway, there's been lots of good advice given so far. Let your needs and advice here help guide your decisions. 1st, take your time. There may be a few extra tractors for sale during the winter as some farmers/ranchers move up. My buddy's dad just bought (6 months ago) a super clean fresh 4440 (I believe) in Halletsville for a pretty penny. $29K It looks factory new inside and out.
Like the others said I'd divide and conquer. Consider the mesquite as a job all in itself. There are 2 ways to handle it that I know of. Chemically(slow) and mechanically(fast but $$$). It takes a big dozer to pull a good root rake. I'd figure 65-90 $ per hour. A D7 or D8 can pull a 6-8 foot rake and can knock out maybe an acre or more an hour if not too much in the way. This is the best way to destroy them. However, they usually won't quote a job as total amount. They just say $XXX to deliver and $XX per hour, you tell them when to stop.
A tracked skid steer with a tree sheer can easily sheer them above ground and you can easily see your progress. At least the thorns stay on the trunks and you can carefully haul brush with a grapple to a burn pile. Then you need to squirt chemical on the stump.
Chemicals are not cheap. I think Remedy is about $100/gallon. Mix it 1qt with 3 qts diesel for a gallon of mix. Then just put a small amount of chemical on the crown of trunks near the base. When you get out there and figure that you have 50-100 trees per acre or so, well it takes a lot of time and a lot of chemical. You should keep a gallon handy anyway if you want to control. I would recommend that you don't sign up your city wife for this duty as it is very boring and hard to see any progress. You never know she might be a trooper.
If your 1020 is worth fixing, do it. Get yourself a post hole digger, box blade, and FEL to start. Your angle iron disc will work OK but the stumps might be hard on it if they stick up too far. Your 1020 can pull a 6 foot disc with scalloped edges easy enough. Don't add any weight to it while you have stumps.
If money was no object, I'd recommend a 100 HP cab tractor and a modern 4wd utility but it is so here's what I'd do.
Look for clean used equipment to do the tasks at hand. A 2wd 100 hp machine will pull just about anything you'll need. There are many dealers in the area. Some will back a used unit for 30 days or so. If you get something and decide you don't need it, you can sell it if it's not a pink elephant and get your money back.
   / Advice would be appreciated #33
The 4320 was built/sold in 1971 and 1972. It was Deere's second entry into the turbo engine market. The 4520 was the first. (1969 and 1970) At the same time as the 4320 was in production, a larger model, the 4620 was also sold. (4520 was 120HP, the 4320 was 116 HP, and the 4620 was 135 if memory is correct)
   / Advice would be appreciated #34
Farmw/junk... Thanks for the info, 67 and 72 popped in my head when I wrote that post... had a 50/50 chance at geting it right /forums/images/graemlins/tongue.gif
Hard for me to remember those dates as they are right at or right before I was born (i'm a 71 model myself).
By the way, we actually have a 5020 (Pretty rough, don't use it any more) and we have the JD dozer blade for it. And lots and lots of wheel weights. Seven U Bar ... in the mood for a "project" 133 HP tractor? It used to pull our 12'7" JD disc fast enough to dig a ditch. /forums/images/graemlins/grin.gif
   / Advice would be appreciated #35
</font><font color="blue" class="small">( I should add the question with regard to the older tractors (of all brands--say between late '60 s and whenever you would have to stop to avoid less well built models )</font>
This is where you have to do your homework and study features with each model, besides the general condition of tractor. Some features I'd consider:
Personally, I don't trust powershift, Torque Amp or the like on old tractors unless I see a recent rebuild receipt.
Synchro, instead of sliding gear which are very awkward shifting and inefficient.
Dual pto shafts for versatility
Hydraulic flow
Minimal electronic gadgetry.
ROPS canopy or cab
100hp range tractors that are real bargains are out there, but not many are green, save Olivers. /forums/images/graemlins/grin.gif Keep an eye out and the right one will come along.
hudr: That's good news on parts. I knew you could buy some of the stuff but that really is encouraging. I have been doing a little research and the 4320 is one that looks like a possibility. I notice it (as well as a lot of these older J.D. s, has both 1020 and 540 RPM, and I believe RonR earlier said that the two shafts ran different implements. Am I correct in assuming that the two shafts on the 4320 are of the two different shaft sizes? Does the turbo feature introduce any maintenance issues?
The 5020 sounds incredible. But 13,000 pounds? That might be too much of a real man's tractor. You may be a '71 model, but I'm a '45 model in need of an overhaul, with some sheet metal and pieces of the carburetor missing!
Kyle: We really are neighbors and while I'm at it, let me thank you for anything you might have done to get that new Cabelas built down the road. It's a great source of spare hog rifles, among other things. I hear you and the others loud and clear on the dozer solution, and in fact, may have to have one on both places to repair some minor erosion on stock tank outflows, so with the delivery price being what it is, no time like the present.
MMM: Thanks for the info on features to look for--anything else you think of, let me know. I realize at this point that there will be a price premium on anything Deere--this is just my takeoff point. And you really have to admit that the 1020 would look cute sitting next to one of it's big brothers. Everybody would say "Awwwww." Or not. /forums/images/graemlins/smile.gif
   / Advice would be appreciated #37
I grew up in the country and just recently moved back too. We started with 20 Acres and I bought a JD 2210. The 2210 is too small for a place this size.
I ended up selling the 2210 and upgrading to a JD 4720 and a JD 757 mower. The 4720 is an excellent tractor, HST trans is very easy to use, FEL, 4wd, etc - it was an good choice for an all around tractor. I probably could have lived with a 4320 or a 4520 but it was not much more money for the higher HP. Oh well, I call it the swiss army knife of tractors - all kinds of implements, tc.
Well, we ended up buying the 160 acres next door. I found myself sweating like Mike Tyson in a spelling bee out there and I wanted a bat wing mower. My 4720 would not handle a batwing, but the MX-6 sure is handy. So, I decided on a 5525 cab with a HX-15 batwing. The 5525 will fit on my trailer I use for my 4720. I kinda wanted a 6415 (not that much more money) full size frame, etc, etc but it would not fit on my trailer, is a lot bigger, and I figured it woudl be total overkill for my needs. Having a cab rocks.
I keep debating a FEL for my 5525 but I have one on my 4720. Moving round bales when it is really cold makes me want to put a FEL on my 5525, but it really cuts down the forward visibility I like to have when mowing, etc.
All in all, I think I have a pretty good combo. The 5525 wont run the largest of roun balers, etc but it should do fine. I don't plan on doing large row crop type stuff (read big disc) or I would have gone bigger. The 4720 gets the most use, but part of that is because the 5525 with the batwing can do jobs in less than half the time.
On the fence row stuff, a skidsteer can be handy. A dozer even more handy. it really depends on what you want to do. I just put in 3 miles of new fence and the tree lines along the fence rows looked so nice after I cleaned them up, I tore down the old fence and moved it over 5'. I have a hard time cutting down really nice trees.
Get you JD up and running. You might want to add a FEL to it. I would run it for awhile and see what you think before you sink the money. The ergonomics of the new tractors is really nice. The price of a FEL for your JD would make a nice downpayment on a new JD. The financing on new tractors is pretty godo these days. Yes, they are more money but from a cash flow perspective (warranty, age, etc) it might make sense to buy new equipment.
There are some good deals on used equipment, but you have to be careful. If you want John Deere tractors, it seems that the resale is so good on them you almost should buy new. When I bought my 5525 i looked at some 20yr old tractors and they were still a lot of money considering they were 20 yrs old, etc. Resale on implements is much lower - used seems to be a good route if they are in good shape.
Let us know how it goes.
D.
Thanks for the input, ddivinia. I'm kind of like George Washington--I listen to all my generals' advice, then ponder and make a final decision. Oh, wait! He lost all of his battles except 2 or 3.
Seriously, I did tell the dealer I asked to pick the 1020 up to think about what it would take to put either a new or used FEL on the tractor and he pointed out that since it has no power steering, and a lift capacity of 2000 pounds, it would be a real b***h to drive with the bucket loaded. Hadn't though of that one.
Russ
   / Advice would be appreciated #39
I think he is right. Adding a FEL migth be good money after bad. Once you use a modern tractor, I doubt that old one will get much use...
You kinda need to look at the one off projects vs. long term stuff. In some cases for the one off sttuff you rent a unit or buy a used one with the intention of dumping it at the end of the project. In some cases - hiring out the off the wall stuff is not a bad call - if the gear breaks - it is their problem.
So many options,
D.
   / Advice would be appreciated #40
Russ, my little B7100 had a front end loader, but did not have power steering. My B2710 had both. If you'd like to build up your arm muscles then a tractor without power steering is the way to go. /forums/images/graemlins/wink.gif
2013 Ford Explorer AWD SUV (A50324)
2013 Ford Explorer...
Tree Boom (A50322)
Tree Boom (A50322)
MAXUM M-1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM M-1000...
2019 CATERPILLAR D5K2 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
TOYOTA 42-6FGCU25 LP SIT DOWN FORKLIFT (A50854)
TOYOTA 42-6FGCU25...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
