Advice on building a tractor shed?
   / Advice on building a tractor shed? #31
I have never ever heard anyone say they built their garage too big....
You can always downsize
An old man told me years ago "That sounds like a great idea, build a $100,000 Barn to protect your $100,000 worth of equipment"
Yes..
   / Advice on building a tractor shed? #32
I suggest at least 6 ft all around the tractor as open space so you have plenty of space to work on it. A 12x12 door sure adds flexibility going in and out. My neighbor had a post rot out. My builder used 3 2x6's nailed together rather than 6x6 posts since pressure treating can't get to the center of the post but 2x lumber is fully treated. Leave the center one short at the top to slide the roof truss in. I have translucent fiberglass at the top 2 ft of the side walls which lets a lot of light in. Have a ridge vent and windows for ventilation.
   / Advice on building a tractor shed? #33
I would never want center posts in a storage building. It would only be a matter of time before I hit one. :D
My very first thought when I read the original post. I'm sure I'd hit one in the first couple trips in and out.
   / Advice on building a tractor shed? #34
I think the old man was wrong . . .
As you say, you can always downsize. Chances are you WILL fill it up, sooner or later.
Your $100,000 worth of equipment will last longer, take less maintenance, keep its value better and work better if it isn't left out in the elements and is protected from theft, vandalism, joyriders, critters, you name it. Remember, your equipment was bought to WORK, it wasn't bought because it was a trophy of some kind. If it won't work, you are losing money.
In 20 years, the value of the equipment inside the barn could easily be $200,000 or more, the barn is still $100,000.
If it is part of a business (farming, used for business purposes, etc.) you can deduct any interest payments on the mortgage and you can also depreciate it. Don't forget expenses - maintenance, power, and so forth.
When you go to sell, it will appraise (assuming it has been kept in good condition) at current replacement cost or close to it, which is going to be WAY more than you paid for it 20 years ago. (Exception - I am given to understand that in farms, the value is in the land which makes income and structures on it are not as important in the valuation.)
You will also have had the utility value of it for all the time you owned it. Mini-storage is atrociously expensive and there is a national shortage of warehouse space.
Size matters, bigger is better.
Best Regards,
Mike/Florida
   / Advice on building a tractor shed? #35
The Open End should face EAST as prevailing winds are from the West. Build the door way at least 16" higher than your ROPS. Shelving along the sides, 8' x 2' wide Work Benches at either end but along the side. One at back one at front (open end) LOTS of Lighting and outlets. Consider 220V service for Welder roughed in. A 4x4 Washroom is a valuable addition.
   / Advice on building a tractor shed? #36
I had cardinal carports build me a 28x36 with 2 10x9 roll up doors and a 36 in walk door. Last yr. i love it , Had it put on concrete , Best thing i ever did , You will regret going to small , Spend a little more now or alot more later.
   / Advice on building a tractor shed? #38
Yes. And the worst eyesores are those places with multiple small sheds. Build one right-sized building.
Well now I am looking at going with a steel carport thanks to you guys.....and my wife agrees.
Jethro B - where did you find that 18 x 21'...?
   / Advice on building a tractor shed? #40
Either a carport style or a full garage is my thinking.
Rodents have a field day the more enclosed but not 100 enclosed…
Keeping the sun and rain at bay to my thinking provides the most bang for the buck…
air compressor (A55758)
air compressor...
2017 Chevrolet Trax LS SUV (A55973)
2017 Chevrolet...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A56858)
2018 Ford F-150...
LOT: Uline 72" Rolling Staircase, 6' Fiberglass Stepladder (A59076)
LOT: Uline 72"...
JOHN DEERE TRACK TRACTOR (A54756)
JOHN DEERE TRACK...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
