Adding Valve to Closed Center Post Pounder
   / Adding Valve to Closed Center Post Pounder #1
cwbwi
John Deere 2555
Hello All!
I'm working on a custom hydraulic shift on my Shaver post pounder. I would like to add an additional 2 valve bank to the existing 3 valve system to power some additional hydraulic rams. The current valve is closed center and powers 3 rams, the final ram on the pounder is one way, so the return line dumps to the tank on the tractor, not back to the SCV.
My question is how to plumb in the new valve into this system. Am I correct in assuming that I should tee off the line from the tractor SCV and tee the return line to the tank because this is closed center? The shaver dealer is telling me I can put an open center valve with power beyond before the closed center valve, that doesn't seem right to me. Attached is a picture of what I'm working with.
The post pounder is on a John Deere 2555 tractor (closed center, 23 gpm, 2320 psi). Also, am I correct in assuming that I should turn the relief valve pressure setting on both these valves all the way up since the tractor has its own relief valve?
I'm considering purchasing this valve, the handles can be positioned similar to the existing valve and the specs seem to fit. It comes with a closed center plug and is reasonable at $112. What are your thoughts?
Thank you for your help!
   / Adding Valve to Closed Center Post Pounder #2
Yes you can add the second valve with two ways to do it.
One is to get a closed center plug for the new valve, mount it on the port that would be the power beyond port on a open center system. Then you tee the pressure lines of both valves and also tee the two tank lines together.
The other way is like the dealer said. You get a power beyond adapter, and tee the pressure lines, then the tank lines. But the new valve with the power beyond needs to be placed before the shaver valve, so the closed center plug on the second valve can still be effective.
I wouldn't adjust the pressure relief valves on the valves yet. They usually come preset at around 2600 PSI, or at least the ones sold here are that way. As you said, the pressure on the tractor is 2320 PSI.
   / Adding Valve to Closed Center Post Pounder #3
Do it the way you have outlined. Tee the supply and returns, use the valve you have selected and buy and use the closed center plug in the added valve.
I would not adjust the PRVs.
   / Adding Valve to Closed Center Post Pounder #4
I'll disagree with RickB because a closed center control valve utilized on a JD 2555 needs the PRV closed completely or at least set above 2320 psi or frt hyd pump will most likely cavitate. JD closed center hyd control valves utilized on that model tractors don't require a relief valve & definitely will not operate correctly with an open center valve attached to closed center hyd system
   / Adding Valve to Closed Center Post Pounder #5
Once again you are correct, my friend.
   / Adding Valve to Closed Center Post Pounder #6
I would follow dealers advice as he probably has had a ton more experience than any single contributor on page.... And the logic is correct....
Dale
   / Adding Valve to Closed Center Post Pounder #7
Dale
Dale
If Shaver dealer states to install an open center valve on a tractor with closed center hyd system such as a JD 2555 then the dealer needs to attend a hyd school as he's giving incorrect hyd information. No I'm not a dealer BUT I was employed at a JD dealership for over 21 yrs with 13 of those yrs I served as dealer service manager. Closed center hyd's will not function as designed with an open center valve installed!!
   / Adding Valve to Closed Center Post Pounder #8
Dale
22 years of dealership experience here and I have been around Deere closed center systems and Shaver drivers since the 1970s.
Some dealers have a wholesale supplier with a catalog of short line stuff that is available for retail sale. This dealer may never have seen a Shaver driver in person or set one up. Theoretically an open center PB capable valve upstream of a CC valve will work, but it is a needlessly complex installation.
   / Adding Valve to Closed Center Post Pounder #9
RickB
Would you please explain how to connect an open center valve on a closed center hyd system so CC hyd pump won't cavitate.
Thanks,Jim
   / Adding Valve to Closed Center Post Pounder #10
RickB
Thanks,Jim
It would have to be a Open Center Power Beyond valve. Just a Open Center valve wouldn't work.
You would take the line off the pump running into inlet of the valve, run the Power Beyond line out a Closed Center valve, then run the tank line into the Tank circuit.
As was said, needlessly complicated and it would just be easier to put in a closed center conversion plug to plug the power beyond port.
Aaron Z
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
RYOBI 3300 PSI GAS PRESSURE WASHER (A51248)
RYOBI 3300 PSI GAS...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
2018 BIG TEX 70CH 84" X 20' CAR HAULER TRAILER (A51247)
2018 BIG TEX 70CH...
2021 Kubota SVL97-2 (A50123)
2021 Kubota...
Cherokee camper trailer (A51694)
Cherokee camper...
