Adding second set of brakes
/ Adding second set of brakes #1
bones1
Platinum Member
St.Marys County. Maryland/Tall Timbers Md.
Farmtrac 300 dtc
i'm sure someone here has added a second set of brakes to their double axle trailer.How difficult is it to do.I would like to do it if it is not too involved.
/ Adding second set of brakes #2
It is very simple IF the mounting flanges are ON the axle. I done mine a while back and it was about 3 hours start to finish.
/ Adding second set of brakes #3
It's somewhat easier for electric brakes than hydraulic, but a long afternoon will have it done either way. If you are splicing into electric brakes, solder the connections, coat with liquid electric tape and use shrink wrap. That way, you won't be chasing electrical gremlins.
jb
/ Adding second set of brakes #4
If your trailer has Dexter axles or probably most axle companies, they sell brake kits that you can add to the idler axle. Its pretty simple to do. As others said, be sure to seal up your wiring splices. RTV silicone work well too.
/ Adding second set of brakes #5
I was going to do it to my car hauler. I priced the parts where I bought the trailer. They offered to do the install for $20, so I let them. JC
/ Adding second set of brakes #6
Check your prices carefully, I found it cheaper to buy an entire new axle, then to buy the backing plates with brakes and the drums.
Does not make a lot of sense, but that was the way the $'s came out for me.
/ Adding second set of brakes #7
Be careful using RTV or silicon sealer that contains acetic acid on electrical connections. It is corrosive.
/ Adding second set of brakes #8
Acetic acid = vinegar. That nasty vinegar smell you smell when using silicone. I wouldn't use it on electrical stuff, instead, I use the paint on electrical tape from the auto parts store. It holds up very well to UV and stays flexible.
/ Adding second set of brakes #9
Thanks for the tip on RTV silicone. I didn't know that. I have used it in the past without problems. I Always learn something new here.
John Deere 5420 Tractor with Quicke Loader (A64047)
John Deere 5420...
UNUSED RAYTREE RMVR76 - 76" VIBRATORY ROLLER (A62131)
UNUSED RAYTREE...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
PT 1000 Gallon Supply Tank (A57149)
PT 1000 Gallon...
(2) ROW PLANTER (A62130)
(2) ROW PLANTER...
2022 BIG TEX 22GN-35BK+5MR T/A 48FT GOOSENECK TRAILER (A59909)
2022 BIG TEX...
