Adding rear remotes
/ Adding rear remotes #11
I bought the JD kit for my 1025 when I bought the tractor new. I installed the kit. Ultimately, I was mostly happy, though JD did a few things wrong: There were nearly twice as many lines, and some mounting plates as I needed. Okay, so different versions of the tractor may require different lines, but for an expensive kit, I have nearly as much left over as I installed - and I can't return the unused new parts. The major parts (lines & mounting plates) came loose in a large box, with no caps on the lines. So I blew them all out with care. The small parts, including the control stickers were all poured into on plastic bag - the stickers were munched.
I'm happy with the fit and function of the kit, but there were some customer satisfaction misses. I'm kinda thinking that maybe JD parts sales do not intend that the tractor owner do the installation. If done at a JD dealer, the tractor owner would not see the wasted excess parts!
My friend with the JD 3038E decided to buy a valve cluster and cylinders for a DIY installation. Which is fine. He's more than capable of making brackets and hoses.
My question now is where do we plumb into the hydraulic system for the supply and return?
/ Adding rear remotes #13
My 3038e has power beyond...a hydraulic loop that I uncouple, connecting to valve for hydraulic top link cylinder, etc.
/ Adding rear remotes #14
Look at the links Brian (@MtnViewRanch ) and I posted above and download the install instructions, that should help you determine where the feed and returns go.
HOBBS 48FT FLOAT (A55745)
HOBBS 48FT FLOAT...
20' SINGLE AXLE INDUSTRIAL TRAILER (A59823)
20' SINGLE AXLE...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2016 Ford F-150...
2016 JOHN DEERE 135G (A58214)
2016 JOHN DEERE...
2019 CHEVROLET SILVERADO LD CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2018 Isuzu FTR Landscape Dump Truck (A59230)
2018 Isuzu FTR...
