Adding rear remote to L3750
   / Adding rear remote to L3750 #1
tehillah1
Colorado
Kubota L3750
I have a Kubota L3750 with a front loader and hydraulic top-link and leveler cylinder on the rear. The rear hydraulics are run through a 4 spool valve body with one spool not in use. The other three spools control the 3pt, the top-link and the leveler cylinder.
I recently purchased a 3pt backhoe w/bobcat style quick disconnects. I need to set up a quick connect system to the rear of my tractor for this unit. How do I set up a seperate set of remotes for this? Can I use the hydraulics that are already there for the leveler cylinder? Is there a way to run the hydraulics off of the unsued spool in the valve body?
Any input would be appreciated.
   / Adding rear remote to L3750 #2
Break out the ole wallet and begin to cry, this endevour will set you back at least $800.00 for just a single rack, 2 will be over $1k. I'm in the same boat as you.
Thanks for the reply. I got the job done for $167.00. Went down to Universal Tractor and picked some brains there, had a couple of hoses made that I plugged into the unused spool and bingo, the Woods 7500 works like a charm. I use a 99 cent bungee to keep the valve open when I'm using the hoe.
This was easier than I thought and I kinda had a hunch it didn't need the big-bucks set up to make the process work.
Finding the right guy who really knows hydraulics seems to be the ticket.
PALLET OF JACKS AND JACK STANDS (A58214)
PALLET OF JACKS...
2017 FORD F-450 XL BUCKET TRUCK (A58375)
2017 FORD F-450 XL...
SKID STEER ATTACHMENT (A58214)
SKID STEER...
New/Unused Stand on MX-MRW14 Wheel Loader (A57453)
New/Unused Stand...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
New/Unused 7ft Work Bench (A57454)
New/Unused 7ft...
