Adding rear hydraulics to L2250
   / Adding rear hydraulics to L2250
I emailed Nate today and also looked at the add on info in the Kubota parts manual. It sure seems like it would be way more economical to add aftermarket parts. I understand the keeping it all kubota argument, but my machine is close to 30 years old. I just want it functional.
Do all three spools feed the rear? Or are you running a grapple on the bucket with one of them?
   / Adding rear hydraulics to L2250 #24
Yes it sure would be a lot less money going aftermarket, but did you see where you can tap into the rockshaft?
   / Adding rear hydraulics to L2250 #25
On my L2550 I have a factory rear and it is connected to the valving below the seat and the control is on the right fender. It was never used by the previous owner I assume as the hoses were connected backward to the tractor side when I got it. I will pull the schematic (if it is there) from the shop manual and send it to you by E-mail. Just PM me your address.
I just ordered my service manual yesterday. The pdf parts manual I have consists of very small pictures. I couldn't really tell where it was tapping into the system.
   / Adding rear hydraulics to L2250 #27
I could run all three to the rear but now the 3rd is for a grapple... Plan to have a cylinder to angle my rear blade someday.
   / Adding rear hydraulics to L2250 #28
On my L2550 I have a factory rear and it is connected to the valving below the seat and the control is on the right fender.../QUOTE]Do you have photos of your set up???
Here's what Gregg sent me. Nate from Messicks is looking to see what is still available. If I can get the piece under the seat to tap into the Hydraulics the rest shouldn't be too difficult.
   / Adding rear hydraulics to L2250 #30
UNUSED SDLANCH 72" QUICK ATTACH BUCKET (A57193)
UNUSED SDLANCH 72"...
GROUNDHOG ZH12G EXCAVATOR (A57192)
GROUNDHOG ZH12G...
2016 Ford Fusion S Sedan (A53424)
2016 Ford Fusion S...
UNUSED PABREAK AR650 HYD AUGER (A57193)
UNUSED PABREAK...
2008 Isuzu NPR-HD Landscape Dump Truck (A53422)
2008 Isuzu NPR-HD...
(2) SLIP ON 76" FORK EXTENSION (A57193)
(2) SLIP ON 76"...
