Adding Power Beyond, 3-spool hydraulic valve, and T-n-T to a JD 2520
   / Adding Power Beyond, 3-spool hydraulic valve, and T-n-T to a JD 2520 #131
Hi!
the valve you are using, is it for closed system or not? or have anything to say?
Regards Jarle from Norway:)
This is the data for a JD 2320
Hydraulics:
Type: open center
Capacity: 2.6 gal [9.8 L]
Pressure: 2421 psi [166.9 bar]
Valves: 2
Pump flow: 3.4 gpm [12.9 lpm]
Total flow: 5.6 gpm [21.2 lpm]
Steering flow: 2.2 gpm [8.3 lpm]
So, you should be using an open center hyd valve.
TractorData.com John Deere 2320 tractor information
Some valves are convertible, in that the valve may be just an open center valve with a shallow plug in the PB port.
An optional PB sleeve or set screw is available to convert the valve to PB.
Another option is for closed center and that is a plug to close off the PB port. The fluid from the cyl ports is the only fluid to exit the OUT port.
If you install a plug in a PB sleeve, that will also make it a closed center valve.
   / Adding Power Beyond, 3-spool hydraulic valve, and T-n-T to a JD 2520 #132
i am using my power beyond port on my 2320...
what type of control valve do i need to tilt my box blade? i want something that will not flot, something i can set so the blade goes to a certain angle and stays there but allows my hydraulic pump to not keep running.
please advise...
   / Adding Power Beyond, 3-spool hydraulic valve, and T-n-T to a JD 2520 #134
Great thread, thanks for posting this.
I have a 4500 with just the loader, no 3SVC or PB or anything. Does anyone know if it's the same under there with the plate, set screw, etc?
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
2014 Ford Fusion Sedan (A56859)
2014 Ford Fusion...
2000 Club Car DS Golf Cart (A57453)
2000 Club Car DS...
1000 Gallon Supply Tank (A53314)
1000 Gallon Supply...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
