Adding pony motor
/ Adding pony motor #1
spo307
Levittown & Long Eddy NY
kubota L4400
I have a high ranger bucket truck and was looking add a pony motor to run hydraulics, manual says 8 VPN I have a 13 hp Honda motor can someone point me to a pump and slip clutch or whatever makes it work, I would fabri ate mounting plate etc. pro has 1" inlet and 3/4 discharge thanks for the help or Any ideas dennis
/ Adding pony motor #2
Your 13 HP Honda engine could power a 6.5 cu in pump at 3000 psi.
/ Adding pony motor #3
find out how many GPM the truck pump is and don't go over that, to many GPM might make things move faster than you want.
/ Adding pony motor #6
That should have been 6.5 GPM at 3000 psi.
Need a .4 cu in displacement pump running at 3600 rpm.
2006 TerraGator 8104 (A63688)
2006 TerraGator...
213074 (A64276)
213074 (A64276)
36" X 12' ADS DRAINAGE PIPE (A64281)
36" X 12' ADS...
(2) TOOL BOXES (A62613)
(2) TOOL BOXES...
211297 (A62131)
211297 (A62131)
(2) 480/70R28 TIRES W/ 8 LUG RIMS (A64280)
(2) 480/70R28...
