Adding pony motor
/ Adding pony motor #1
spo307
Gold Member
Levittown & Long Eddy NY
kubota L4400
I have a high ranger bucket truck and was looking add a pony motor to run hydraulics, manual says 8 VPN I have a 13 hp Honda motor can someone point me to a pump and slip clutch or whatever makes it work, I would fabri ate mounting plate etc. pro has 1" inlet and 3/4 discharge thanks for the help or Any ideas dennis
/ Adding pony motor #2
Your 13 HP Honda engine could power a 6.5 cu in pump at 3000 psi.
/ Adding pony motor #3
find out how many GPM the truck pump is and don't go over that, to many GPM might make things move faster than you want.
/ Adding pony motor #6
That should have been 6.5 GPM at 3000 psi.
Need a .4 cu in displacement pump running at 3600 rpm.
CAT D5G LGP DOZER (A58214)
CAT D5G LGP DOZER...
2009 Haybuster GP-50 Grain Processer (A55315)
2009 Haybuster...
96in. Fork Extensions (A61567)
96in. Fork...
Manure spreader for sale
Manure spreader...
Kubota B21 TLB (A60462)
Kubota B21 TLB...
2019 VOLVO SD115B SMOOTH DRUM ROLLER (A62129)
2019 VOLVO SD115B...
