Adding lights to my 3316
/ Adding lights to my 3316 #1
montyhp
Adkins, TX
Mahindra 3316g
I would like to add some front and rear facing lights to my ROPS. There are two connectors behind the seat that are taped up. I assume that those are for canopy lights. Does anyone know if they are switched with the headlights?
Any suggestions on what kind of lights to put on?
/ Adding lights to my 3316 #2
I believe that those wires are hot and ground for the factory rear work light. I think that the oem work light has the switch on the light itself and is not controlled by the headlight switch.
I used these Peterson V502HF 3 By 5 Inch Tractor Utility Light #8874125 at HardwareAndTools.com on my 3215. They have worked out very good for me. Here is a link to a thread that I started on the improvements that I have done to my 3215. http://www.tractorbynet.com/forums/mahindra-owning-operating/158287-3215hst-improvements.html
Thanks, I'll have to get out my VOM. I'll look for a switch.
Those lights look good. I have to measure to see if I can fit 4 on the ROPS.
2022 BOBCAT E35i R2 SERIES EXCAVATOR (A65053)
2022 BOBCAT E35i...
2025 Mounting Plate Skid Steer Attachment (A64553)
2025 Mounting...
2015 Peterbilt 320 T/A McNeilus Front Loader Garbage Truck (A64556)
2015 Peterbilt 320...
Forestry Drum Mulcher Skid Steer Attachment (A64553)
Forestry Drum...
2014 IC Corporation PB105 School Bus (A64194)
2014 IC...
2018 MACK LR633 6X4 T/A GARBAGE TRUCK (A66091)
2018 MACK LR633...
