Adding insult, and more injury......and a bit irony..............
   / Adding insult, and more injury......and a bit irony.............. #1
bswiv
Palatka, Fl
CAT D5G, Kubota M8540, KubotaB2700
So with some helpful input from folks here I managed to get the blades sharpened and back on the JD MX7........which took most of day before yesterday. Felt good about it too, no wobble and the test cut was good.
And then, today......about 2 hours into mowing fire breaks I somehow managed to SNAP the output shaft. Felt something and when I turned around to see what was up I see the whole stump jumper unit laying the the fire break.......and I am smelling 90 weight gear oil.
So now the question is.......what to do.......options?
How hard is it to replace that shaft into the gearbox?
Or is the right thing to do to sell the thing for parts and get a heavier duty unit?
   / Adding insult, and more injury......and a bit irony.............. #2
was it a finish mower? did you see what caused the impact & shaft failure? maybe some pics.
good thoughts on the outcome
Not a close up but you can get the idea.
Not a finish mower.....a John Deere MX7 rated for 2".
   / Adding insult, and more injury......and a bit irony.............. #4
A Doctor would say, Good Thing it was a clean break.
   / Adding insult, and more injury......and a bit irony.............. #5
That's bad luck … I think it's deere part DE19034 Shaft and mating bevel gear. About $1300. I'd look for a whole new gear box before tearing into the gears.
This is what I was thinking.
Though when the wife saw me ride up with it held in the grapple she said: "You should by a new mower, something tougher." Which sounds like permission to me!
   / Adding insult, and more injury......and a bit irony.............. #7
That doesn´t sound like permission, that sounds like a direct order :D
   / Adding insult, and more injury......and a bit irony.............. #9
Agree w/hoss. There is probably significant damage to the gear box internals, maybe even a cracked case. You must of hit something pretty solid. A heavier mower may not fare any better unless you find the culprit. It could be quite a way back before it finally sheared off.
Ron
   / Adding insult, and more injury......and a bit irony.............. #10
MX’s are famous for this if you google around a bit, very expensive mower to have this happen!
STORAGE SHELTER KIT (A53843)
STORAGE SHELTER...
2018 Ford Transit 250 Cargo Van (A55852)
2018 Ford Transit...
Fimco 15 Gallon Sprayer (A54865)
Fimco 15 Gallon...
New/Unused CFG Industrial QK20R Mini Excavator (A54865)
New/Unused CFG...
Pair 2 - ST225/75R15 radial trailer (A53421)
Pair 2 -...
