Adding Hydraulic Side Links
/ Adding Hydraulic Side Links #51
3RRL said:
One thing I found was very useful with the tilt cylinders. Instead of raising and lowering the 3pt to modify grading the road or a cut in the gutters, I found I could more easily...and with more control...use the hydraulic cylinders by extending or retracting them individually. They responded faster and more accurately. I set the position control on the 3pt so the box blade was several inches off the ground and then lowered each cylinder until I got the desired cut...either level or tilted. The only time I had to use the 3pt was to raise the box blade high.
Very good point 3RRL. Most people would miss that concept. What you describe is how a road grader works. Two independent systems control one blade. On my JD grader the two lift levers sit side by side. So close together that the knobs can touch. That allows me to run them with one hand, both knobs in my palm, then twist the wrist to cause action. Works great!!! Good job 3RRL!!!
Hey guys,
Thanks for all the great comments. And it's great to get so much interest. I really appreciate it.
The project sure was fun and the results prove to be beneficial. Customizing the tractor and implements has really made my tractoring a better experience, and made my tractor a "better" tractor. It is unbelievable how a little thing like being able to reposition your implement without having to get off the tractor can be. Sure, you can do it manually like many of us do everyday.(me...used to:) ) But now I spend more time accomplishing work and less time jumping in and out of the tractor making adjustments. I don't think I've ever gotten it perfect the first time so I'd have to do it several times.
You eliminate all the stress and strain to adjust those heavy turnbuckles, especially with a bucketful of dirt. And there have been plenty of times I really needed to make an adjustment but said "screw it" because I didn't want to hassle with it. Once I get used to adjusting the valve and pick the right speed, there's no excuse now for a perfect job.
One more thing brought up by ovrszd about using the cylinders like a grader does. There was a reason I chose those big cylinders with the Ø1-3/4" shafts and 8" stroke over the normal smaller ones with 4" stroke. I can position the upper lift arms on their splines so that the boxblade can be below ground level with cylinders fully extended and the upper arms all the way in the "up" position. I would have to rely on retracting the cylinders to lift it up. Then I'd have that "down force" that's missing when needed.;) That could be useful in some applications. My 55hp Kama is pretty big and with FEL, Hydraulic boxblade and 4 loaded tires it has to be pushing 7,000lbs.
I haven't set it that way because I need to check if it will work for my other implements. But if the cylinder stroke allows me enough vertical clearance, I'll do that...maybe for only an inch or two so as not to put too much stress on the 3pt casing. I know it can take it because I've bottomed out the boxblade many times with it raised up going over dips and gulleys and gotten an immediate box full. With the cylinders either completely or partially retracted, the 3pt would still be able to float down and I could still use the draft and position control, like normal use.
/ Adding Hydraulic Side Links #53
great job. When you get your tractor to the point you cant make room for any more mods, I will let you borrow mine to keep your skills up:) :) Im sure you will enjoy that tilting box blade.
/ Adding Hydraulic Side Links #54
Afternoon Rob,
I dont know how I missed this thread :confused: Now that Ive had a chance to read through it, really enjoyed the whole thread !
What a terrific job, as usual ! The thing that makes it real interesting is that you have a real need for a boxblade that can tilt on an angle for your drainage ditches.
I dont know Rob, I think your becoming a hydraulics expert ;) :)
Great job, and keep em comin :D
/ Adding Hydraulic Side Links #55
man ive got a 6' rear blade and it doesnt look NEARLY that big.
how big is your BB?!?!
Pat,
LOL...You put out the fires at my house and I'll gladly do some mods on your tractor. I've always liked tinkering with stuff being a mold maker but just never had the time before.
Scotty,
I'm surprised you missed it too? Yeah, I use my box blade almost every time I go up to the property. Even more than the fel. I wanted the tilt on the tractor for another project I'll be starting that requires some maneuverability. So it's not just for he box blade. And I'm no hydraulic expert either. I learned everything here on TBN, mostly from MadReferee about how it works. I've always worked with cylinders though....just not the valving or tractors.
schmism,
My box blade is (was) a 7' Howse. I've modified it and beefed it up to make a hydraulic gear drive to raise and lower the scarifiers. It now weighs in at nearly 1,000lbs. In case you missed that thread, you can go here:
GEAR DRIVEN HYDRAULIC BOX BLADE Here's a picture of it now.
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2011 SOUTHWEST  GOOSENECK (A58214)
2011 SOUTHWEST...
2019 FORD F-150 STX CREW CAB TRUCK (A59823)
2019 FORD F-150...
2012 AMERITRAIL (A55745)
2012 AMERITRAIL...
2022 CAN-AM BOMBARDIER LIMITED RTV (A59823)
2022 CAN-AM...
Lot of 4 10-16.5N.H.S. Skid Steer Wheels and Tires (A59228)
Lot of 4...
