3RRL
Super Member
- Joined
- Oct 20, 2005
- Messages
- 6,931
- Tractor
- 55HP 4WD KAMA 554 and 4 x 4 Jinma 284
Aaahhh...I see what you mean. Thanks for the clarification. When I checked the movement for clearance I did not have the draw bar in the lift hooks which would cause the twist in the lower drag link. At this point I'm hoping Pat's EZ Change system allows enough movement...it did before but that was with slightly wider yokes. I am definitely going to have to check that out and report back.deerhunterf350 said:I believe Jinman was referring to the Lift Arms Twisting , or rotating Left or Right as the Tilt was adjusted.
See attached Diagram
Condition A shows both cylinders set equally, the Implement is level
Condition B shows the most extreme Tilt you can achieve , and the Lift Arms tilt along with the Implement.
Thanks,
