Adding hydraulic oil BX
/ Adding hydraulic oil BX #1
bird1968
Canada NB
BX24 after years of BX22
Hope this help someone filling the oil.
This is what I've been using, add the pin to hold funnel.
I only had to add a small piece rubber hose at the tip, to extend reach (Walmart funnel).
Bird
/ Adding hydraulic oil BX #3
Adding oil with that funnel will take for ever and spill all over the place. I just changed all fluids on my BX2200 and gave it a try and it did not work out. I used my big funnel and it went a lot smoother.
Enjoy!
/ Adding hydraulic oil BX #4
I just used a similar setup this weekend thanks to your post. Thanks!
/ Adding hydraulic oil BX #5
I use the same funnel to fill my tractor with fluids. It took a long time to feed 7 gallons of UTF through that thing in January. The hardest part of the whole 50 hour service was holding the 5 gallon jug up for that pour. I still use the funnel, beats the heck out of the alternative.
2015 Ford Transit 250 Cargo Van (A61573)
2015 Ford Transit...
2018 Dodge 5500 Bucket Truck 4WD (A63689)
2018 Dodge 5500...
Caterpillar Standard Job Description Manuals (A63117)
Caterpillar...
(3) 24.5-32 TIRES & RIMS (A63291)
(3) 24.5-32 TIRES...
John Deere 1023E (A62177)
John Deere 1023E...
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
