adding hydraulic fluid to BX2200
/ adding hydraulic fluid to BX2200 #1
duner9
Central New Jersey
Kubota BX 2200
Hi fellow BX 2200 owners. Where is the drain plug to fill or check the hydraulic fluid on this tractor. My neighbor and I own the same machine, and we can't figure this out. Please help.
Thanks,
Duner
/ adding hydraulic fluid to BX2200 #2
At the rear of the tractor, above where the top link connects there is a orange plug, this is where you add the oil. To the left of the plug there is a dipstick that checks the fluid level.
There are two marks on the stick, indicating the upper and lower fluid level, as long as you are between these marks your ok .
/ adding hydraulic fluid to BX2200 #3
Those plugs may be gray colored or painted over. Your question is covered in the Operators Manual. You will need to get a funnel with a long hose attached or make one up. First time I changed out fluid I think more Super UDT went on the floor than in the tractor. The transmission filter is on the lower forward and the strainer is on the bottom left hand i think.
Wow, your neighbor also has a BX, I bet y'all have a lot of fun. J
Thank you guys for posting replies. On my machine there is a bright orange drain cap over the rear axle. My neighbor and I just thought that that was the cap for the axle and not the whole hydraulic system.
Happy holidays,
Duner
WOODS 3120 BATWING MOWER (A60430)
WOODS 3120 BATWING...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
PORTER CABLE AIR COMPRESSOR (A63569)
PORTER CABLE AIR...
2025 78in. Hydraulic Dual Cylinder Rock Grapple Skid Steer Attachment (A61572)
2025 78in...
207272 (A52708)
207272 (A52708)
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
