adding hydraulic fluid to BX2200
/ adding hydraulic fluid to BX2200 #1
duner9
Central New Jersey
Kubota BX 2200
Hi fellow BX 2200 owners. Where is the drain plug to fill or check the hydraulic fluid on this tractor. My neighbor and I own the same machine, and we can't figure this out. Please help.
Thanks,
Duner
/ adding hydraulic fluid to BX2200 #2
At the rear of the tractor, above where the top link connects there is a orange plug, this is where you add the oil. To the left of the plug there is a dipstick that checks the fluid level.
There are two marks on the stick, indicating the upper and lower fluid level, as long as you are between these marks your ok .
/ adding hydraulic fluid to BX2200 #3
Those plugs may be gray colored or painted over. Your question is covered in the Operators Manual. You will need to get a funnel with a long hose attached or make one up. First time I changed out fluid I think more Super UDT went on the floor than in the tractor. The transmission filter is on the lower forward and the strainer is on the bottom left hand i think.
Wow, your neighbor also has a BX, I bet y'all have a lot of fun. J
Thank you guys for posting replies. On my machine there is a bright orange drain cap over the rear axle. My neighbor and I just thought that that was the cap for the axle and not the whole hydraulic system.
Happy holidays,
Duner
2019 Ford F-250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F-250...
KALMAR AC P50BX-PS WAREHOUSE FORKLIFT (A64276)
KALMAR AC P50BX-PS...
2021 Bobcat UV34 4x4 Gas Utility Cart (A64553)
2021 Bobcat UV34...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
2006 Utility 53Ft T/A Reefer Trailer (A64194)
2006 Utility 53Ft...
17in. Bucket w/ Teeth Excavator Attachment (A64194)
17in. Bucket w/...
