Adding draw hook to FEL
/ Adding draw hook to FEL #1
N1ST
Enfield, CT
Kubota B7800
I'm considering looking for someone to weld a draw hook to the FEL on my SCUT. I know nothing about this, so I have some questions I'm hoping folks can help me out with...
What size hook is a good choice? I have one marked 1/2" G7... is this fine?
Where on the FEL - top, back ?
Should I have it painted (black) after welding?
What is a fair price to pay?
Anything else I should know?
Thanks!
/ Adding draw hook to FEL #2
What size chain do you have? I use 5/16", so the 5/16"-3/8" hooks are a good choice for me. 1/2" sounds a little big.
Usually they are put in line with the cylinders, you also might have to reinforce the top edge of the bucket.
What color is your bucket now? Just a touch up with spray paint is fine here-it's a bucket, not a show car.
Can't say here, but if you post your exact location someone here might help you for a six-pack. I would if you were near me.
Try searching the post's here, this is one of the most talked about subjects here on TBN
/ Adding draw hook to FEL #3
Match the size to whatever chain you will typically use. I have three 3/8 hooks on my bucket. Also your welder will appreciate it if you get a flat-backed hook as they are made for welding on - see this link as a reference.
~paul
/ Adding draw hook to FEL #5
Instead of hooks why not just weld a piece of 3x3x3/8 angle to the top then cut slots in the angle 7/16" wide then you just drop the chain in the slot to the length you need. On my FEL I have 3 slots 1 6" from both ends and 1 in the middle. It can support any amount that your tractor can lift. It is easy to adjust the chain, just move it to what ever link that you need. If you want to take the chains off just roll the bucket all the way over and back up the chain will slide out. A chain wont bounce out of slot like it will with a hook. Just my 2c worth
/ Adding draw hook to FEL #7
Just make sure you weld them in-line with the loader arms. This is the strongest point of the bucket and loader. Do not weld them on the outside edges of the bucket. You will twist the bucket or possibly even the loader. We've gone to the slot style as a standard component on our new buckets and customers really seem to like the strength and ease of the self-locking style.
/ Adding draw hook to FEL #8
Toolsorbust,
Can you post a picture or two of yours, I would love to see it, I think I understand but the whole "a picture is worth...yada yada" Thanks
/ Adding draw hook to FEL #9
Thanks!
Here are the hooks on the LA302 bucket that's attached to my Kubota B7510HST (21 hp engine).
The dealer did a nice job including welding a stiffener on the bucket before attaching the hooks.
Got the hooks from awdirect.com.
Dealer put them on gratis when I bought the tractor new in May05.
/ Adding draw hook to FEL #10
Yea, slots are good until you try to use ratchet straps to hold a load you don't want marred up by a chain! Hooks are much more versatile. :)
Thanks for the input. I only have 1 chain - it's 3/8". I too would like to see a picture of the "slot" approach.
Mounting the hook upside down along the top seems popular. Doesn't that mean that the bucket has to be extended to use the hook and aren't the cylinders most fragile when extended?
/ Adding draw hook to FEL #12
Here is the lot style we use on our buckets. Two aligned with loader arms, not at outside edge of bucket.
Can they be purchased? Will they fit any loader? Any particular angles?
/ Adding draw hook to FEL #14
They're available as a part. Because I don't know what your top rail on your bucket looks like I can't say for sure on the fit, however you should be able to make them work. Possible stiffner on top edge? They are a square piece of steel with the cut out (rounded top corners). I think they're about $15 each.
/ Adding draw hook to FEL #15
Another source for either the hooks or the weldon slots is awdirect.com. That is where I got my parts. Service was good even though it was a small order.
I stole my design directly from this site, probably from flusher. The only difference was I angled the outer hooks in slightly so there pull is aimed at the middle when they are both used lifting something in the middle. The carabiner style in the center has been very useful.
2016 Etnyre Falcon Live Bottom Trailer (A62613)
2016 Etnyre Falcon...
Kubota ZG222 (A60462)
Wooden Side Table (A61569)
Wooden Side Table...
UNUSED WOLVERINE QC1-26-20G UNIVERSAL HITCH (A62131)
UNUSED WOLVERINE...
2020 INTERNATIONAL MV607 (A58214)
2020 INTERNATIONAL...
UNUSED RAYTREE RHBC72-72" HYD BRUSH CUTTER (A62131)
UNUSED RAYTREE...
