Adding an output shaft to a Yanmar engine
/ Adding an output shaft to a Yanmar engine #1
777funk
Yanmar/336D
Most engines seem to have a flywheel to a clutch. I have a situation where I will be repowering a skid steer from an engine with an output shaft. I could just go with a Honda v twin with the right shaft diameter but it seems for the same money I can buy a Yanmar with around the same displacement. But how would I couple the flywheel to a shaft output?
/ Adding an output shaft to a Yanmar engine #2
I built a little generator unit with a surplus Yanmar engine a few years ago. I just cut a 1/4" steel plate that would bolt to the flywheel. It had a hole cut in the center of the plate where I could weld a flexible jaw coupling. The coupling was almost press fit tight in the hole so it was easy to center and it was all CNC cut so, while not perfectly centered I'm sure, it was pretty darn close. Worked really well.
2013 KENWORTH T800 DAYCAB BOBTAIL VAC TRUCK (A65643)
2013 KENWORTH T800...
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
2010 John Deere 1720 (A64126)
2010 John Deere...
2015 Volvo L30GS (A62180)
2015 Volvo L30GS...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
2004 International 7400 C&C 017797 (A62613)
2004 International...
