Adding A Tach
/ Adding A Tach #1
BigD23
Platinum Member
Pac. NW
Kubota BX23 TLB
Since my Kubota BX23 has no tach, I usually run it by "feel" but never max out the throttle...Would like to stay consistent rpm wise for my tiller and other implements run off the pto...Does anyone have an after market tach they've attached to their tractor that they would endorse? Thanks.
Don
/ Adding A Tach #3
I would love to have a small analog Tach for my 2350 but I have never came across one. I hate digital tach's I don't know why Kubota would build a tractor with out a analog tach?
/ Adding A Tach #4
I like the Tiny Tach and have it. 3 problems. Batteries may be an issue, they have not been for me. Connector at engine should be painted over if exposed. Cable need to be electrical interfernence free.
A bit hard to read, but I love having the hour meters and such. All in all a purchase that I am very happy with.
/ Adding A Tach #5
Datcon makes some nice 3 3/8" tachs. You can get them in magnetic pickup, ignition, or alt. pole driven. Also with or without hour meter. All are sweep hand (analog display) and available in 0-3000, 0-4000 and 0-6000rpm. Datcon also makes other matching gauges. (amp, oil, etc.)
Go here for the number: Datcon's Heavy Duty Automotive-3-3/8" Tachometers with Hourmeters
Then here for the tach: Translectric, Inc. The Heavy Duty Parts Pros
If you get the mag. style, don't forget the pickup sensor.
/ Adding A Tach
Hey guys, thanks as usual for the very valued inputs.
Don
/ Adding A Tach #7
Just remember that diesel tachs need a sender as there obviously is no electrical spark signal to pick up. So get that too (normally sold separately).
jb
/ Adding A Tach
jb
Was reading about that John...Thanks for the heads up.
Don
2012 Caterpillar CB54 Articulated Vibratory Tandem Smooth Drum Roller (A61572)
2012 Caterpillar...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
2008 MACK CHU613 DUMP TRUCK (A63569)
2008 MACK CHU613...
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A61573)
2014 Ford F-150...
12 in. WRXLS Excavator Bucket (A64194)
12 in. WRXLS...
Willmar 4550 Wrangler Articulating Loader (A63689)
Willmar 4550...
