Adding 3rd function to GC2400
   / Adding 3rd function to GC2400 #1
blackd
Platinum Member
So MD
Yanmar FX24D replaced with Massey GC2400
Has anyone done this? Question is cross posted in hydraulics forum.
   / Adding 3rd function to GC2400 #2
There are a ton of threads about this topic if you search. Many use diverter valve kits to accomplish this.
I should have been more precise in my description. I want to add a 3rd function spool connected to the existing valves (power beyond) and not a diverter. Has anyone done this on a GC2400?
   / Adding 3rd function to GC2400 #4
Ah, ok.
First thing you would need to verify is if your loader control valve has a power beyond port as this isn't necessarily garaunteed on a smaller tractor. Newer GC1705/1710/1715/1720 (like I own) loader models have Nimco Valve's that don't possess a power beyond port thus requiring the use of an electronically activated diverter valve 3rd function add-on which is added inline to either you dump/curl or lifting/lower circuit.
I'm not entirely sure what valve body older GC23xx and GC24xx systems used. Should it have a power beyond port you can buy pre-configured kits or build your own kit which are both cheaper than anything OEM/Dealer installed as an aftermarket. The toughest part will be plumbing/wiring in tight spaces, matching an converting fittings to make sure everything mates properly, and keep stuff out of harms way. These little machines aren't swimming in space for add-ons to be installed.
Some people might argue that these machines aren't big enough for such an add-on but to that I say it's purely user discretion. I've seen this class of little tractors do some great work with a 3rd function setups and a grapple attachment or a plow blade whether it's a MF, John Deere, Kubota, ETC. The videos are out there to watch.
Thanks cglaseer104. What I intend to do is add a connection to the output port of the existing valve. Running it to a 2nd spool valve. Then from that new spool valve's output add a connection to that disconnected line from the output port of the existing valve. I think this output line goes to the transmission (holding tank). If I am correct this is the same/similar as replacing the current 2 spool with a 3 spool system.
2015 Z Master Professional 5000 Series Model 74942 60in Zero Turn Mower (A50322)
2015 Z Master...
Crash Mobile S/A Trailer (A50324)
Crash Mobile S/A...
2010 Hyundai Elantra Touring Sedan (A51694)
2010 Hyundai...
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A51242)
2021 CATERPILLAR...
UNUSED FUTURE 60" VIBRATORY ROLLER QUICK ATTACH (A51244)
UNUSED FUTURE 60"...
EZ-GO MPT 1000 Electric Utility Cart (A51694)
EZ-GO MPT 1000...
