Adding 3rd function to GC2400
   / Adding 3rd function to GC2400 #1
blackd
Platinum Member
So MD
Yanmar FX24D replaced with Massey GC2400
Has anyone done this? Question is cross posted in hydraulics forum.
   / Adding 3rd function to GC2400 #2
There are a ton of threads about this topic if you search. Many use diverter valve kits to accomplish this.
I should have been more precise in my description. I want to add a 3rd function spool connected to the existing valves (power beyond) and not a diverter. Has anyone done this on a GC2400?
   / Adding 3rd function to GC2400 #4
Ah, ok.
First thing you would need to verify is if your loader control valve has a power beyond port as this isn't necessarily garaunteed on a smaller tractor. Newer GC1705/1710/1715/1720 (like I own) loader models have Nimco Valve's that don't possess a power beyond port thus requiring the use of an electronically activated diverter valve 3rd function add-on which is added inline to either you dump/curl or lifting/lower circuit.
I'm not entirely sure what valve body older GC23xx and GC24xx systems used. Should it have a power beyond port you can buy pre-configured kits or build your own kit which are both cheaper than anything OEM/Dealer installed as an aftermarket. The toughest part will be plumbing/wiring in tight spaces, matching an converting fittings to make sure everything mates properly, and keep stuff out of harms way. These little machines aren't swimming in space for add-ons to be installed.
Some people might argue that these machines aren't big enough for such an add-on but to that I say it's purely user discretion. I've seen this class of little tractors do some great work with a 3rd function setups and a grapple attachment or a plow blade whether it's a MF, John Deere, Kubota, ETC. The videos are out there to watch.
Thanks cglaseer104. What I intend to do is add a connection to the output port of the existing valve. Running it to a 2nd spool valve. Then from that new spool valve's output add a connection to that disconnected line from the output port of the existing valve. I think this output line goes to the transmission (holding tank). If I am correct this is the same/similar as replacing the current 2 spool with a 3 spool system.
LandPride PFL1242 Pallet Forks (A50120)
LandPride PFL1242...
UNUSED AGT MXMRW14 STAND ON WHEELED SKID STEER (A51243)
UNUSED AGT MXMRW14...
2012 CHEVROLET SILVERADO 2500HD (A52472)
2012 CHEVROLET...
Sky Trak 10054 Legacy 10K Telehandler (A51573)
Sky Trak 10054...
CATALOG IS A GUIDE ONLY!! (A50775)
CATALOG IS A GUIDE...
Braided 1" Cable (A50515)
Braided 1" Cable...
