Added a Rear View Mirror
/ Added a Rear View Mirror #1
yooperdave
Marinette, WI
Tool Cat 5600, LS XJ2025H, Branson 4215HC
Bought a 4' piece of L2x2, mirror, longer bolts and spray paint.
Drilled holes to fit and matched the paint with your input.
Yooper Dave
/ Added a Rear View Mirror #2
I did twins. Used 1/2" conduit and adjustable mirrors. They wiggle a bit, but not too bad. Haven't painted them yet.
577437d1541350521-what-did-you-do-your-mirror1-jpg
577439d1541350543-what-did-you-do-your-mirror2-jpg
/ Added a Rear View Mirror #3
A $23 Jeep Wrangler mirror is an easy bolt on option ...
/ Added a Rear View Mirror #4
I've posted this before, but I'm reposting after using 2" spot mirrors for a number of months and finding how effective they are in providing awareness of things around me, especially when I am working or transporting where cars approach from the rear.
The mirror in the image is pretty old, but it attaches in seconds with double stick foam tape to each of the bucket supports plus it can be "tilted" to put the focus where you need to watch.
Amazon has similar adjustable mirrors at 4 for $6
/ Added a Rear View Mirror #5
Those look like branch benders to whip back and hit you in the face. I have one of those cheap self adhesive round mirrors on my truck which work good to eliminate the blind spots but I never considered putting them on the tractor. I might use that idea.
/ Added a Rear View Mirror #6
After almost 20 years I finally ordered some appropriate size clamps to mount a rear view mirror on my Mule front roll cage. It vibrates so bad, being a diesel, it is useless, and worse, annoying. I need to try and take any spring out of the mount.
/ Added a Rear View Mirror #7
Nice, simple approach.
The Jeep Wrangler mirror I mounted has very little vibration. I was luck enough that there were a couple of holes in the loader mount. I used a piece of wood and threaded inserts to cinch it all down.
/ Added a Rear View Mirror #8
Is it big enough? I like to be able to see if a vehicle is coming a quarter of a mile down the road.
/ Added a Rear View Mirror #9
The depth perception of the little round mirrors isn’t good. They work great for seeing a blind spot in a vehicle but nearly useless for much else.
/ Added a Rear View Mirror #10
That's what I kind of figured. Add into that, bad eyesight.
/ Added a Rear View Mirror #11
That's why I went big ... and adjustable. I can position mine high, low or to either side as necessary based on what I'm doing or need to see. I just can't bend and crane my neck the way I used to.
/ Added a Rear View Mirror #12
That probably depends if their lights are on ;-)
Seriously, the viewing experience is the same as most passenger side mirrors, so, for that requirement, it's probably time to break out the welding torch and/or drills and taps to mount a large flat mirror... and keep an eye out for low branches.
For the price as well as the installation requirements, it's easy to give one a try.
Beverly Howard
/ Added a Rear View Mirror #13
A vehicle flying down the back roads at 85 KPH can be on you pretty quick.
/ Added a Rear View Mirror #14
I went 'big' after trying the small, round, mirror type. I found a generic 'Van' replacement mirror (with mounting arm) at my local autoparts shop.
The local fabrication shop knocked up a mounting plate to fit the holes on my FEL post. I ensured that I cut a rubber gasket between the plate and the FEL to cut down on vibration; the result was no discernible vibration at all.
STIHL HT103 POLE SAW (A62613)
STIHL HT103 POLE...
2020INTERNATIONAL MV607 4X2 S/A 26FT NON CDL BOX TRUCK (A59914)
2020INTERNATIONAL...
2016 Dodge Charger Sedan (A59231)
2016 Dodge Charger...
New/Unused CFG Industrial MH12RX Mini Excavator (A65583)
New/Unused CFG...
1999 Sterling Dump Truck (A66285)
1999 Sterling Dump...
(7) DONALDSON P600676 AIR FILTERS (A64276)
(7) DONALDSON...
