Add on hydraulics
/ Add on hydraulics #1
obxtractor
Is there a place on a CK 30 to add another set of hydraulics? I feel that it would be more cost effective(possibly) to tap in another pressure and return line with a separate control valve for a grapple. It seems that all of the other dicussions are based on diverters. Why do most people use them?
/ Add on hydraulics #2
I think people use the diverter setups because they are relatively cheap, easy to install, and a well known company makes them model specific to our tractors. A guy like me who can put stuff together but doesn't really want to get in over my head finds comfort in knowing he can buy a "kit" and be done with it.
/ Add on hydraulics #3
Hey Highbeam...
Do you know what company makes the diverter kits for Kioti (CK25/30 specific)? I'm looking at putting a grapple on mmy CK25 bucket and I'd like to find the diverters and everything else I'll need to get it running.
Thanks
/ Add on hydraulics #5
Cool!! I think I'll order mine this evening.
On another note... Where do most folks mount the switches...or...is there something out there even better? My hydraulic control arm won't allow me to put the switch directly in the handle. Any good suggestions??
Thanks
/ Add on hydraulics #6
I'm thinking of using a small 'handlebar kill switch' for motorcycles.
Something like so.....
/ Add on hydraulics #7
I may be the only one using rear remotes to control a grapple but I must say that I am perfectly happy with that arrangement. If you have rear remotes or have some other excuse to get a set it makes a lot of sense to try them as a means of grapple control before investing in a diverter valve or solonoid. The cost of installing a set of rear remotes is less than the cost of adding a diverter and you get multiple functions out of it. It also requires zero skill to connect a grapple via rear remotes. Just measure for the right amount of hydraulic line and get the appropriate fittings attached. Then you just need a fist full of zip ties to secure the lines as you route them to the FEL.
I think some people are unhappy with the idea of taking your hand off the FEL controller to reach back for the rear remote control lever (usually on the right fender). I gotta say that after about a day or so of use it is no more difficult than shifting 4 on the floor. I used to look but it is totally automatic now. I cannot imagine there is even a half second lost in moving my hand. You can control the grapple just as finely as with a diverter too. I chickened out proving that yesterday when I was taking a movie of my grapple use and tried to shut the camera off by touching the shutter button with the grapple tooth....I gave up because I couldn't judge the distance closely enough, not because I couldn't control the grapple finely.
/ Add on hydraulics #8
Greenecho said:
Hey Highbeam...
Thanks
I am most familiar with the WR Long kit made specifically for our machine. There is nothing wrong with mounting the diverter switch to the loader control stick or just buying a replacement ball for the stick with a button in it. You will just have to route and restrain the wiring to keep it safe. It should be an easy install but those things cost money.
/ Add on hydraulics #9
Like Highbeam says, WR Long makes a great valve. Below are the numbers I used. I ordered them through a local Kubota dealer who ordered them from Long for me.
The valve is the soleniod diverter valve, giving me a true third function grapple.
The valve part number VALDO3S2C12D-35
The Subplate part number VALSUBPLATED03
(This valve needs the subplate to go with it.)
The Handle is number G3-0100HANDASY4
The handle replaces your joystick handle and has the switch in it.
Or you can go to their website for the set up you want and contact them.
W.R.Long the 4N1 Bucket People
/ Add on hydraulics #10
Thanks for all the feedback. On another note (Kioti) specfic...
Can these diverter valves handle the hydraulic pressure that controls the curl function of the loader? I was thinking of putting the diverter directly in line with the hydraulic hoses that control the curl funtion of the bucket.
Usually these diverters are used on the FEL control and I wasn't sure if there was a pressure difference in the FEL control hoses versus the hoses that actually control the hydraulics.
Thanks..
/ Add on hydraulics #11
OBX, Do you have a set of remotes already?
If so another set can be added for a total of 2 sets.
Pricing isn't too bad on them either.
BTI
/ Add on hydraulics #12
That is the normal way to connect the diverter.
Not sure what you mean here since the diverter usually connects to the work ports of a loader valve spool. The diverter will have two outputs, one will go to one set of cylinders and the outher output will go to another set of cylinders. An electronic switch is the usual means for selecting which output will be selected. Pressure is not an issue if you have the diverter sized correctly for your tractor's hydraulic system.
A "third function" valve connects in series with the loader valve and is totally seperate from any loader valve spool functions. WR Long sells both diverters and "third function" valves.
/ Add on hydraulics #13
This is the way I've used my grapple until a month or two ago. I needed/wanted my rear remotes free for my hydraulic toplink and also another set for the other functions listed in my diverter thread.
Steve
/ Add on hydraulics #14
Steve
Now that is a good reason to install a diverter (or a second set of remotes):rolleyes:
22" PIN-ON EXCAVATOR BUCKET W/PINS (A60429)
22" PIN-ON...
2016 FORD EXPLORER SUV (A64280)
2016 FORD EXPLORER...
2016 Ford Explorer AWD SUV (A61574)
2016 Ford Explorer...
2018 Western Star 4900 Tandem Dump (A62613)
2018 Western Star...
2006 FREIGHTLINER M2 106 T/A BOX TRUCK W/100 PSIG AIR PUMP (A59912)
2006 FREIGHTLINER...
2014 Ram 2500 4x4 Crew Cab Pickup Truck (A64194)
2014 Ram 2500 4x4...
