add lighting
/ add lighting #1
textedford
mahindra 1626,ford 8n
hi guys new to this forum i have a mahindra 1626 tractor love this tractor i have 1,000' of driveway to plow snow in the plow hides the headlights how do i wire lights to the rollbar(i think two pods one on each side)thanks tex.
1950,8n ford.
2021,1626 mahindra.
/ add lighting
hi roadworthy ok made the clamps,lights on the way how do i wire them in thanks tex
/ add lighting #4
Check your fuse panel. My Kubota has a fuse for the work light. My connector was under the left fender I learned from a Kubota website. The fuse was rated at ten amps. I purchased a mating connector for my factory connector and was able to power my lighting from there. I added a switch because that circuit was hot whenever the ignition was on. I also checked the actual current draw of my light bar before ever connecting it to the tractor. It was five amps so I was well inside my safety zone. I don't know Mahindra at all and if they don't have a work light fuse you may need to run a line from your battery all the way to an inline fuse and from there to any switch you want and then to your light. It's not hard but may take a bit of planning. The light you choose will dictate the wire size. I strongly recommend stranded wire over solid wire as the constant vibration will cause solid wire to break at the worst possible time.
/ add lighting
hi roadworthy yes got all that i am a electrician by trade i have the" service manual" for this tractor but couldn't find anything on it but thanks for the help anyway tex.
1950 ford 8n
2021 mahindra 1626
/ add lighting #6
check the rear side, near the mid pto, there was a wiring plug on my 26 for a horn/lighting, was taped up, but had a label
/ add lighting
hi LittleBill21 ok is this plug on driver or passenger side(sitting in the seat) thanks tex.
/ add lighting #8
near the mid pto lever side, driver side, blue tape? butt connectors, was in the same harness as the mid pto controls.
look at this post
4th picture is where i tied into this plug.
/ add lighting
hi Littlebill21 found it the label said 3a.can't use that 2-40w lights is 80w or 6.66a will have to do something else but thanks for the help tex.
/ add lighting #10
yep, 3a for lights 2a for horn. led lights should work for you though, not sure why they derate it so much, wire is thin, but its tied to the 10a fuse in the panel.
something like this should work
/ add lighting #11
For ultimate electrical versatility
/ add lighting
hi LittleBill21 yes true for one at 100% is 1.5 amps but for two at 80% load is 2.4 amps not good (18w lights) thanks tex.
/ add lighting #13
not sure why you are derating the label, the circuit is fused at 10amps. Do what your comfortable with though.
/ add lighting
hi LittleBill21 your not protecting the lights your protecting the wire/ system tex.
/ add lighting #15
main fuse at the distribution block protects the wire. the 80% derating, was a nec code for commercial "constant" on applications where nuisance tripping could occur, it had nothing to do with the wire itself.
again do what your comfortable with.
/ add lighting #16
Just what would be the WORST that would happen if you drew enough to blow that 10 amp fuse?
Where the wire is, you aren't going to start a fire or do any real damage.
I'd worry more about operating without a helmet then electrical damage from ru.nning a couple lights
2006 Peterbilt 379 T/A Sleeper Cab Truck Tractor (A64194)
2006 Peterbilt 379...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2014 Ford F-150 Pickup Truck (A64556)
2014 Ford F-150...
2019 East Manufacturing 48ft. T/A Walking Floor Trailer (A64556)
2019 East...
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
