AC Question
/ AC Question #1
Toddfromtexas
Massey Ferguson 3660
Recently purchased a 94' 3660, air blows but not cooling. Cleaned coils, Compressor is kicking in and cycles when temp. is adjusted.
I am looking to check freon levels, but only finding 1 fitting on the back side of the Sanden compressor. Should there be 2 a high and low side if so where an I missing the other fitting.
Thanks
/ AC Question #2
Thanks
I haven't seen a system that did not have both fittings for your gauges. Normally, the high side pressure line should be the smaller line going to the compressor and the suction (low pressure) side should be the larger line. Try tracing those lines backwards from the compressor and see if you don't find a separate fitting in each line somewhere in the plumbing. Not so easy to find in some set-ups...
/ AC Question
Thanks, I am in the process of tracing lines.
2003 Sterling L7500 S/A Day Cab Truck Tractor (A64556)
2003 Sterling...
2024 Polaris Sportsman 570 AWD ATV (A64557)
2024 Polaris...
2026 Stout TB-76 Tri-Blade Brush Cutter (A64047)
2026 Stout TB-76...
2024 Ranger XP 1000 North Star (A62679)
2024 Ranger XP...
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
2007 Jeep Commander (A62613)
2007 Jeep...
