AC Question
/ AC Question #1
Toddfromtexas
Massey Ferguson 3660
Recently purchased a 94' 3660, air blows but not cooling. Cleaned coils, Compressor is kicking in and cycles when temp. is adjusted.
I am looking to check freon levels, but only finding 1 fitting on the back side of the Sanden compressor. Should there be 2 a high and low side if so where an I missing the other fitting.
Thanks
/ AC Question #2
Thanks
I haven't seen a system that did not have both fittings for your gauges. Normally, the high side pressure line should be the smaller line going to the compressor and the suction (low pressure) side should be the larger line. Try tracing those lines backwards from the compressor and see if you don't find a separate fitting in each line somewhere in the plumbing. Not so easy to find in some set-ups...
/ AC Question
Thanks, I am in the process of tracing lines.
2007 INTERNATIONAL 7400 SBA 4X2 VACUUM TRUCK (A63276)
2007 INTERNATIONAL...
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
KOMATSU FORKLIFT (A63291)
KOMATSU FORKLIFT...
2019 HINO 268 26FT 4X2 S/A NON CDL BOX TRUCK (A59914)
2019 HINO 268 26FT...
1952 John Deere A Tractor (A66408)
1952 John Deere A...
2001 Sterling Single Axle Dump Truck SELLING OFFSITE (A62613)
2001 Sterling...
