A thought.......
/ A thought....... #1
DirtHauler
Northern Cali ~~~ "Weed" Country
" '06" Kioti CK30 2015 Mahindra 2555 shuttle 2019 Massey 1760M
Was wondering if I could take the turbo set up for Mahindra 3316 and retro it to my CK30 since the exhaust system is almost the same. And why hasn't Kioti turbo'd any of their 3 cylinder tractors ?
/ A thought....... #2
Usually, when a turbo is added it requires lower compression pistons in order to keep cylinder pressures within acceptable ranges. What you end up with is a larger combustion chamber at similar pressures producing more power.
/ A thought....... #3
Should work ..... don't go too high on the boost ...... if you live at altitude (we're at 5,900' here in town ..... gets higher going East, West & South) that will affect the boost you can run, too. The local shop here has turbo'ed several smaller Montanas and Kiotis with no problems.
Gannon 12in. Bucket with Teeth Excavator Attachment (A64194)
Gannon 12in...
2022 CATERPILLAR 299D3 XE SKID STEER (A65053)
2022 CATERPILLAR...
HONDA Plate Compactor (A64557)
HONDA Plate...
2017 DITCH WITCH JT20 DIRECTIONAL BORING MACHINE (A63276)
2017 DITCH WITCH...
2012 CASE CX350C EXCAVATOR (A65053)
2012 CASE CX350C...
New/Unused Wolverine Quick Attach Coupler (A65583)
New/Unused...
