A thought.......
/ A thought....... #1
DirtHauler
Northern Cali ~~~ "Weed" Country
" '06" Kioti CK30 2015 Mahindra 2555 shuttle 2019 Massey 1760M
Was wondering if I could take the turbo set up for Mahindra 3316 and retro it to my CK30 since the exhaust system is almost the same. And why hasn't Kioti turbo'd any of their 3 cylinder tractors ?
/ A thought....... #2
Usually, when a turbo is added it requires lower compression pistons in order to keep cylinder pressures within acceptable ranges. What you end up with is a larger combustion chamber at similar pressures producing more power.
/ A thought....... #3
Should work ..... don't go too high on the boost ...... if you live at altitude (we're at 5,900' here in town ..... gets higher going East, West & South) that will affect the boost you can run, too. The local shop here has turbo'ed several smaller Montanas and Kiotis with no problems.
2019 Ford F-250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F-250...
2022 EZ-GO ELITE...
2022 EZ-GO ELITE...
2006 INTERNATIONAL 7400 4X2 VACUUM EXCAVATION TRK (A63276)
2006 INTERNATIONAL...
LOT OF 2" SQUARE TUBING (A64278)
LOT OF 2" SQUARE...
2021 TORO 07411EX CART (A66091)
2021 TORO 07411EX...
