A good attachment for BX!
/ A good attachment for BX! #1
samofsweden
Kubota Bx24, 2007
I find the iphone app so useful, so I post this:) Instead of using poison to keep the weed away this works very well!
Talking about if BX has a cat1 or not, I did lenghten my arms by 10cm ( around 4inc)
This to be able to use cat1 implements.
/ A good attachment for BX! #2
What is that thing called? Never seen anything quite like it??!!
Deano
Deano
Well if I try to translate..."weed-harrow" simple as that:confused2:
Its only made for clearing weed on big areas, like in front of your house, driveways ,big plats,
/Sam
/ A good attachment for BX! #4
Figured a harrow of some sort. I even googled weed harrow and no picture of that thing shows up...interesting!
/ A good attachment for BX! #5
Use Google image "Advanced Search" for "harv" with the region being "Sweden." Some photos of larger ones of similar style came up.
Here's one.
Bruce
/ A good attachment for BX! #6
Who is the manufacturer? How much $. Do you think it would be effective in weeding pastures (looks like you're doing a road).
/ A good attachment for BX! #7
Thanx for sharing samofsweden! Interesting implement, specific use though. How does it do in dry ground? Seems it would be better in moist or loose soil by the angle of the harrows. Do the tines in the rear collect the vegetation?, and require periodic dumping?
/ A good attachment for BX! #12
So what is a Field Cultivator for? How is it different from a disc? I've never used a disc but I assume you can set it for different depth penetration. Is a harrow the same as a field cultivator?
/ A good attachment for BX! #13
Not really a farmer so can't comment with certainty but I remember many years back when I was a kid working on a friend's farm for the summers, we used all three. This was wheat farming. Disc really turns the soil over nicely, the other tang style cultivator also breaks up the soil while the harrow was used to breakup the lumps of soil after using the other cultivators. Mind you this 40 odd years ago and I think modern farmers don't do as much cultivating in order to preserve soil from erosion and moisture losses.
2013 Caterpillar TL9430 (A64126)
2013 Caterpillar...
2023 Bobcat T76 (A64126)
2023 Bobcat T76...
2001 WORKHORSE CONVERTED TO FOOD TRUCK (A59914)
2001 WORKHORSE...
2019 Mack Granite Tri-Axle Dump w/ Lift Gate 006043 (A62613)
2019 Mack Granite...
2008 PROCO 130BBL (A65643)
2008 PROCO 130BBL...
2019 K&K Trailer, VIN # 1K9PE2027KA175461 (A65563)
2019 K&K Trailer...
